Old 13-02-2008, 11:54 PM   #1 (permalink)
Default having trouble with windows sound recorder need help
[tab]hi everybody
I m facing some trouble with windows sound recorder.
Yesterday I was recording sound from a cd rom's content using windows sound recorder and that time it was working fine.
then i made some changes to windows volume control, after that it's not working at all
i hav tried every possible settings i know but its not working i have checked all the recording control in volume control properties but the result is same.
tell me guys what to do
vabhu is offline
Old 14-02-2008, 02:19 PM   #2 (permalink)
Default Re: having trouble with windows sound recorder need help
Didn't understand your problem.
Open Volume Control and see that the component you are recording from(mic/line in / cdrom) is not muted.
ThinkFree is offline
Win XPSP2 sound recorder problem... mdp Software Q&A 1 20-05-2007 09:45 AM
WinXP SP2 reboots when try using windows sound recorder! praka123 Hardware Q&A 12 23-01-2006 06:39 PM
nokia 6630 sound recorder COOLdeepak Mobiles and Tablets 1 04-11-2005 02:02 AM
Sound Recorder (?) Problem direct_2d QnA (read only) 5 08-08-2005 01:02 AM
- by chris
