13-02-2008, 04:48 PM
MVP Awardee 07
Ccleaner,Adware2k7,revo uninstaller help
I,ve tried using ccleaner,adware2k7,revo uninstaller provided on the digit discs...
Ccleaner,Revo uninstaller:=
It spotted out many .dmp from Minidump folder and many log files from the system 32 folder,plus many missing registry keys,from mui cache and many places....Is it safe to let Ccleaner,Revo remove those keys..
Adware 2k7:=
This too spotted out a few registry entries with the name "Dataminer" located in HKCU...Is it safe to delete this too???
Can i trust these apps??
Probability of me getting a ps3=0
Probability of me getting crazy about ps3=1
13-02-2008, 04:55 PM
Re: Ccleaner,Adware2k7,revo uninstaller help
Ya these apps are trusted by all even I use all these apps...
Offtopic:-
BTW U have Join Digit : Aug 2006
and till now 46 posts.
Why..??
13-02-2008, 07:53 PM
i am sorry to say mentioned softwares are bogus.last time i used ccleaner it removed file may be it was .dll or something like that.i had to reinstall
i recommend registry mechanic 7 or reg cure.you know where to download dont you?
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
13-02-2008, 09:46 PM
I also recommend Registry Mechanic but the main problem is that needs to be bought. I've used CCleaner and it is fine but it can't be compared with registry mechanic. However, you can still use it and do not forget to create a System Restore point before performing the clean.
26-02-2008, 06:44 PM
MVP Awardee 07
Offtopic:-
Why..??
B'coz the replies u get from this forum is too low...
Digit sure is loosing its appeal..
26-02-2008, 07:39 PM
C# Be Sharp !
You can surely trust CCleaner [Crap Cleaner] .
There are 10 types of people in the world: those who understand binary and those who do not.
26-02-2008, 07:47 PM
Distinguished Member
AdAware 2007 has now become bloatware; but sure, you can still trust it and CCleaner...
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
26-02-2008, 08:28 PM
Mad and Furious
Offtopic:-
Why..??
no offence, but everyone does not postcrap like you...
Yes, you can rely on these s/w.
26-02-2008, 09:51 PM
^^ +1
According to my personal experience. I don't like CCleaner even though it is free. Whenever I perform a scan from it, most of the programs in my Start Menu when opened show some kind of MSI installation i.e. they are getting reinstalled again. I don't know why it happens...... So I've stopped using CCleaner for Registry repairs......
26-02-2008, 10:10 PM
^^ u must edit the settings of cclener
BTW im on ubuntu and dont need any software mentiond here
Offtopic:-
Why..??
Reason: Automerged Doublepost
27-02-2008, 02:14 AM
Yes, indeed I fix selective issues and have edited the settings.
Actually, I was warning him not to mess up with Installer/Uninstaller Reference Issues. Only fix those in which you are completely confident. For eg. I had uninstalled 7-zip quite a while ago. So, I fixed the Uninstaller Reference Issues issues of 7-zip.
And also, do take the bake-up of the registry when CCleaner advises so that you can revert the changes when anything goes wrong.....
27-02-2008, 09:35 PM
ya very imp
