Old 13-02-2008, 12:57 AM   #1 (permalink)
Default Problem with hidden folders
hi all,
My software problem is i am hiding a folder and after few days if i select to view the hidden files and folders from the tools menu bar i am not able to see my hidden folder. To find my folder i have to use the search function . Is this any kind of virus or am i supposed to change some settings? Pls help me
Thanks In advance
gsashwin18 is offline
Old 13-02-2008, 02:05 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Problem with hidden folders
Please check the solution of Point 23:
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
not showing hidden folders jayanbhm Software Q&A 25 18-08-2008 05:04 PM
Plz help recovering hidden folders debaisaindian Software Q&A 3 20-09-2007 11:15 AM
can't see hidden files or folders!!!!!!!!!!! Yavin Software Q&A 2 17-07-2007 03:39 PM
how to unhide folders hidden by folder guard?? tango_cash Software Q&A 2 20-02-2007 05:33 PM
Where my hidden folders? rambo QnA (read only) 4 01-12-2005 07:59 AM
- by chris
