Old 11-02-2008, 10:49 PM   #1 (permalink)
Default Urgent Help Needed For Recovering Lost Data
Hi,
I mistakely formatted a hard disk which contained some important pictures. It was divided into two partitions: C => 10gb and D => 60 gb.
The pictures were in D. But to install Vista i repartitioned drive C to 20gb and rest of space to D drive.
NOW is there any way by which i can recover that lost pictures.Kindly help as these pictures are important to me.
vinay_001 is offline
Old 11-02-2008, 11:34 PM   #2 (permalink)
Default Re: Urgent Help Needed For Recovering Lost Data
Try using any data recovery software like PC inspector File recovery. The chances are less but lets hope for the best.
Dont forget to visit my site:http://www.technonix.com
reshadat is offline
Old 12-02-2008, 12:55 AM   #3 (permalink)
mad1231moody's Avatar
According to me u should try GetDataBack
It is great program to recover data from formatted NTFS partitions as well as FAT32. I request you not do any more writing to the harddisk. Cause overwriting means ur data is lost forever
mad1231moody is offline
Old 12-02-2008, 01:42 AM   #4 (permalink)
but can data b recovered even after formatting???
http://thenamemanish.blogspot.com/
mind021 is offline
Old 12-02-2008, 10:00 AM   #5 (permalink)
adi007's Avatar
there are thousands of software available for recovery..but i say just forget about the lost data..there is very less chance that ur data will be recovered and recovered fine..and if have made some activities in ur hard disk,then say bye bye to lost data..
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 12-02-2008, 12:53 PM   #6 (permalink)
Yes u will be able to recover data even if u have formatted the HDD. But only the data that has not been overwritten can be recovered. Best of luck
FRONTECH tv tuner card - stuck lost - urgent help needed sincereheart QnA (read only) 8 27-08-2008 01:37 PM
Recovering from a lost password in Vista. anandk Tutorials 4 21-11-2007 12:51 AM
Urgent !!! Help Lost Very Important Data & Project Source Code mehra.rakesh Software Q&A 4 16-01-2007 05:17 PM
Recovering a lost windows partition pandi Software Q&A 4 04-12-2005 06:26 AM
LOST PARTITION ! URGENT HELP IN DATA RECOVERY NEEDED !!!!!! arnold Software Q&A 4 20-10-2005 02:04 PM
- by chris
