Hi.. I wanted to install vista aero theme created by vista guru Vishal Gupta.Hence I installed vista glazz software but, after installing that I am getting only white classic theme..How to get aero theme?
Thanks..
If you have installed SP1, then VistaGlazz will not work properly. I'll advise you to use Tuneup Utilities to apply the theme. Its easier. I have put all required instructions here:
Vishal I have followed the instructions given by you. When I install Vista Glazz in Vista Ultimate it even refuses to show old basic theme.Will try it with tune up utilities..
@ravi9793
I have all the latest drivers...
Thanks..
