Old 11-02-2008, 02:13 PM   #1 (permalink)
Unhappy DVD to AVI/divx?? PLEASE HELP
hello every1!
i own large cllection of bollywood / tamil/marathi dvd titles.( all of these are legally purchased and not pirated / theatre prints.)
as i m running out of space , i wanto convert all collection to avi/divx wuthout considerable quality loss.
is there any FREE /OPEN SOURCE software to do this?
bharatesh is offline
Old 11-02-2008, 04:20 PM   #2 (permalink)
Default Re: DVD to AVI/divx?? PLEASE HELP
Super
ThinkFree is offline
Old 11-02-2008, 05:57 PM   #3 (permalink)
Attitude matters
Ponmayilal's Avatar
Look into this tutorial DVD2DivX - the easy way guide/tutorial
Ponmayilal is offline
Old 11-02-2008, 09:52 PM   #4 (permalink)
New
New's Avatar
Use VIRTUAL DUB and it's completely free....Good news is it's just 1MB download..
New is offline
Old 12-02-2008, 12:20 AM   #5 (permalink)
megui is the best in this business.
mrbgupta is offline
Old 12-02-2008, 12:35 AM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
AutoGK + DVD Decrypter both are free take a look at this guide
http://www.chotocheeta.com/2007/08/2...-2-cd-dvd-rip/
if u have any CRT display with 17" screen 700 MB RiP with 640 resolution would b fine if u have bigger than that then chose 720 resolution with 1400 MB as size
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 12-02-2008, 01:53 AM   #7 (permalink)
Yep AutoGk is very cool... btw Choto Cheeta, since he says that he is running out of space (assuming that he is talking about the space in his HDD) he can skip DVD Decrypter.
nokia3660 is offline
Old 12-02-2008, 09:25 AM   #8 (permalink)
Attitude matters
Ponmayilal's Avatar
Dr.DivX 2 OSS is a free open source program that is "officially the unofficial DivX encoding tool to create DivX Media Format files for playback on DivX hardware and software players. "
"Generates DivX files which are playable on DivX certified players: Since Dr. DivX respects DivX certification constraints, all files generated by the application are guaranteed to playback on DivX certified hardware players."
You may try both AutoGK and Dr. Divx 2 OSS before deciding which way to go.Finally it will depend on your personal choice. So do experiment before going one way or the other. And do post a short review why you prefer one over the other for the benefit of all.
Old 12-02-2008, 06:35 PM   #9 (permalink)
ok ok !
but i 'll love it if it is a ONE-CLICK dvd to avi/divx application!
Old 12-02-2008, 06:42 PM   #10 (permalink)
vaibhavtek
Posts: n/a
SIMPLE DIVX is the best..!!!
Old 12-02-2008, 06:49 PM   #11 (permalink)
where can i get it???
Old 12-02-2008, 08:22 PM   #12 (permalink)
Attitude matters
Ponmayilal's Avatar
ya, you can download the latest version of SimpleDivx 1.40.25 from here http://www.simpledivx.org/main/index...nc=select&id=2
Since you are keen on a "one-click" solution, nothing can be better than Dr.DivX.As illustrated in the tutorial, just drag and drop all the Vobs together, select the audio track, select the subtitle,select "constrain to 1 file of 700 MB size" and click on encode (your first click). When it takes you to the batch window, just click on the "resume" button (your second click) and that's about it.
Dr. DivX is a 4.08 MB download. AutoGK 8.81MB and Simple DivX 11.83MB.Try all for one conversion. No harm and you will learn a lot.
Good luck.
Old 12-02-2008, 08:54 PM   #13 (permalink)
vaibhavtek
Posts: n/a
google it u will get
http://www.simpledivx.org/main/index...tory&Itemid=29
Old 13-02-2008, 05:28 PM   #14 (permalink)
thanx pals!!!!!!!!!
Old 13-02-2008, 05:33 PM   #15 (permalink)
vaibhavtek
Posts: n/a
no prob buddy
How to burn divx/xvid files to dvd to play in Divx player? casual_gamer Software Q&A 8 01-08-2007 09:49 AM
Burning speed for DivX movies to view on a DivX player webgenius Software Q&A 2 04-02-2007 08:52 PM
which format does divx players support *.divx or *.avi or both? kotha81 Software Q&A 2 23-10-2006 08:29 PM
DivX 6 is out gxsaurav QnA (read only) 12 19-06-2005 02:55 AM
divx and usb gambit Peripherals 6 08-01-2005 08:32 PM
- by chris
