Old 11-02-2008, 06:02 AM   #1 (permalink)
Default Help with IDM partial/stuck download
I was downloading a movie using IDM and as my luck goes it got stuck up at 98.3% and won't continue. Now is there a way to recover this fie and use it?
Given the remaining is hardly 2% at the worse I would be just loosing teh end credits of the movie. . .
I already looked at the target folder and the temp folder used by IDM but no sign of any 680 MB file.
nokia3660 is offline
Old 11-02-2008, 06:14 AM   #2 (permalink)
Rockstar11's Avatar
Default Re: Help with IDM partial/stuck download
hmm... r u sure 98% movie downloaded??
than just search ur movie file name na
Zindagi Toofani Hai... Jahan Hai DuckBurg!
Rockstar11 is online now
Old 11-02-2008, 07:45 AM   #3 (permalink)
but where to search for it? does IDM store the file directly or does it use some intermediate temp name? Anywaz will try to search for the movie name and yes it is done 98.83%
Update: Search didn't find any file with the name
can i use partial torrents ?? coolendra QnA (read only) 8 05-06-2007 04:46 PM
Partial Download sush_digit Software Q&A 6 09-02-2007 10:37 PM
Stuck in pop:ww krazyfrog Gamerz 5 17-07-2006 05:46 PM
getright can not recover partial.download.. need urgent help go_gamez Software Q&A 4 04-07-2006 09:57 PM
Partial upgrade fire QnA (read only) 16 22-10-2004 12:15 AM
- by chris
