Old 09-02-2008, 06:58 PM   #1 (permalink)
Amatur Modder
Question Weird problem due to virus..
Hey friends,
As always......Need help.
My pc got infected with some virus and now whenever I try to open any partiton on my computer, it opens an "Open with" dialog with list of programs.
I have to open the drives with right clicking and selecting open.
I have P4 with 1 gb ram and 80 gb hd, xp sp2, and avast home with latest definations...It won't help.....
Please provide some method to the problem....
niravjadwani is offline
Old 09-02-2008, 07:02 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: Weird problem due to virus..
start in safemode then do a show all files and uncheck hide system files; u will see an autorun.inf in every partition open it see whats in it and then copy a line from it and then google it
http://beingmanan.com
iMav is offline
Old 09-02-2008, 07:04 PM   #3 (permalink)
Smile Re: Weird problem due to virus..
Originally Posted by niravjadwani View Post
Hey friends,
I think ur virus problem is solved but the autorun.inf file still remains in the root of each drive.
When u right click and open ur drive find out a file autorun.inf(might be hidden so enable the option from folder options) and then delete the file . Restart ur computer.
This should solve ur problem!!!
silent008 is offline
Old 09-02-2008, 07:07 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
To delete autorun.inf file ..follow this:
http://www.techhunt.org/node/11
Also, if your virus problem is not solved than.......
1) Turn off system restore.
2) Boot in safe mode with networking.
3) Do full online system scan. You can find few online scan options here:
http://www.techhunt.org/node/72
ravi_9793 is offline
Old 10-02-2008, 02:03 PM   #5 (permalink)
If you want you can also do this:
Open Notepad and copy this and save the file as FixAutorun.bat
@echo off
del "c:\windows\autorun.inf" /f/a
del "C:\autorun.inf" /f/a
del "D:\autorun.inf" /f /a
del "E:\autorun.inf" /f/a
del "F:\autorun.inf" /f/a
del "G:\autorun.inf" /f/a
@echo Now Restart the PC!
pause
exit
ico is offline
Old 10-02-2008, 02:51 PM   #6 (permalink)
iMav's Avatar
^^ that will only delete the autorun file and not the batch file associated with the virus also will not clean the registry entries of the virus
iMav is offline
Old 10-02-2008, 03:07 PM   #7 (permalink)
^ Yes, I know that. He should also have a scan using NOD32 or Kaspersky...... Avast is not that good.
@niravjadwani
Provide more information about the name of the virus.
ico is offline
Old 10-02-2008, 03:17 PM   #8 (permalink)
Amatur Modder
Thumbs down Re: Weird problem due to virus..
Sorry yaar, VIrus name I don't know, and seems like it is deleted. It doesn't appear on the scan.
Also, the fixautorun.inf trick didn't worked, the link provided was also false.
Please friends, any other solution?
(Can't it be fixed with some registry tricks?)
Waiting for the solution......
Old 10-02-2008, 03:22 PM   #9 (permalink)
^^ Did you restart after running that Batch file???
Another way of deleting those autorun.inf files.
1) Go to Folder Options and then to View tab.
2) Enable "Show Hidden Files and Folders" and also uncheck "Hide Protected System Files"
3) Now go to each drive and delete those and restart.......
Sorry friend....I made a typo....You had to save it as fixautorun.bat..
Now try again......
ico is offline
Old 10-02-2008, 04:27 PM   #10 (permalink)
Amatur Modder
Unhappy Re: Weird problem due to virus..
Now try again......
Sorry..No autorun.inf file there....
Still tried the batch file, and it didn't worked....
Posting a screenshot...
Old 10-02-2008, 05:29 PM   #11 (permalink)
Download And Run This Tool
http://www.techsupportforum.com/sect...isinfector.exe
devil_himself is offline
weird problem in XP its_me_jeet Hardware Q&A 4 25-09-2007 10:07 PM
Virus trouble (VERY weird stalker virus) mightyboosh Software Q&A 9 22-08-2007 11:34 PM
weird virus kinda thing ishaan Software Q&A 5 23-03-2006 08:58 PM
WEIRD PROBLEM IN AOE III sahil_blues Gamerz 6 27-12-2005 04:32 AM
weird problem krisjr QnA (read only) 6 23-12-2005 06:52 PM
- by chris
