Old 08-02-2008, 04:48 PM   #1 (permalink)
Exclamation Help - Taskbar Gone
Respected Forum Member,
I need your help, I have Mircosoft Windows XP Professional installed in my system. Everything was working fine..Until one day my task bar is lost. Now I don't have Taskbar, No Start Button, Nothing...Can you People help me out. I tried using Window Button but nothing happens.
Hope you can help me out..
Thanks & Regards,
Prathamesh!!
prathamtawde is offline
Old 08-02-2008, 04:51 PM   #2 (permalink)
slugger's Avatar
Default Re: Help - Taskbar Gone
r u realllllly sure it is gone?
it cud just b minimsed to the bottom [not auto-hide but minimsed]
wen u press the M.S. button does the menu bar come up?
slugger is offline
Old 08-02-2008, 04:57 PM   #3 (permalink)
yup!! i m damn sure...that it is not there...
Old 08-02-2008, 04:59 PM   #4 (permalink)
slugger's Avatar
r all the other things working ,besides the taskbas
is explorer.exe process running?
slugger is offline
Old 08-02-2008, 05:12 PM   #5 (permalink)
yes!! explorer.exe is running...
i start all my application from Task Manager!!
Old 08-02-2008, 05:14 PM   #6 (permalink)
slugger's Avatar
then check this out
After the Windows Logo displays or after you log on to Windows, a Windows XP-based computer may only display the wallpaper, a black screen, or a blue screen
slugger is offline
Old 08-02-2008, 10:53 PM   #7 (permalink)
Fresh Stock Since 2005
are your desktop contents visible? Can you bring up the run dialog on pressing Win+R keys?
http://www.khattam.info
khattam_ is offline
Win 98 Taskbar problem. sr123 Software Q&A 2 20-06-2007 08:31 PM
vista taskbar iMav Software Q&A 14 05-06-2007 03:28 PM
Mac Taskbar BBThumbHealer QnA (read only) 7 18-05-2007 02:28 AM
why taskbar of firefox so big ? mkmkmk Software Q&A 7 14-03-2006 07:46 PM
taskbar deepakuma QnA (read only) 1 25-12-2004 06:38 AM
- by chris
