Old 06-02-2008, 11:33 AM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Unhappy Problem in Safely Removing Ext HDD
i hav a segate free agent 500 GB connected via USB
everytime i try 2 remove it using "Safely Remove Hardware" it gives me a erron that a application is still accessing it.
i checked no chance of a virus... as there is no prob in removin my pen drive.
i even closed de unnecessary apps usin task manager... STILL it gives me de error
what can be de prob... is de prob with de ext HDD, i even tried on diff comps
ankushkool is offline
Old 06-02-2008, 12:20 PM   #2 (permalink)
Default Re: Problem in Safely Removing Ext HDD
Is any program installed in you HDD. If yes, this may be causing problem.
Sometimes it happen with me that if the program that accessed a file from my flash drive, it can't be removed until I close that program
ThinkFree is offline
dll problem in removing flash drive psnegi26136 Software Q&A 1 22-01-2008 07:54 PM
problem with removing themes Angad singh Buying Advice 10 05-02-2007 01:48 AM
Problem removing HDD Sankalp QnA (read only) 10 06-08-2005 12:11 PM
problem while removing and installing winxp harry_nitish Software Q&A 3 16-05-2005 12:06 AM
- by chris
