Old 04-02-2008, 01:54 AM   #1 (permalink)
tango_cash's Avatar
Default how to protect my p.c when it is in hibernation and i am away???
hi i put my p.c in hibernate state and then sometimes i am not around.
how do i prevent anyone from using it???
i put a password on the login but if i am logged in and i hibernate my p.c and i go away then anyone can start it from hibernate state and use it.so how do i make sure no one is able to use it.
tango_cash is offline
Old 04-02-2008, 03:05 AM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: how to protect my p.c when it is in hibernation and i am away???
try a BIOS password.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 04-02-2008, 07:35 AM   #3 (permalink)
vaibhavtek
Posts: n/a
its simple just give password to ur user account or u can also give BIOS password.
Old 04-02-2008, 08:56 AM   #4 (permalink)
The Frozen Nova
casanova's Avatar
Right click on desktop, select properties. In the Screen saver tab, look for the option "On resume display welcome screen" Select this option, now it would display the welcome screen prompting for a password provided that a password is already set
www.nerdweed.blogspot.com
casanova is offline
Old 04-02-2008, 10:06 AM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
what if that "other" user turns OFF the PC
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 04-02-2008, 10:29 AM   #6 (permalink)
vaibhavtek
Posts: n/a
^^ Cannot undersrand what u r asking..??
Old 04-02-2008, 10:34 AM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
if you had used Hibernation mode, you'll know that if you turn it ON, (generally) in the "Welcome Screen", you can turn OFF the PC.
btw Vaibhav, no school today?
Old 04-02-2008, 10:34 AM   #8 (permalink)
Alive Again...
satyamy's Avatar
Question Re: how to protect my p.c when it is in hibernation and i am away???
S1800 means if someone on the PC in hibernation mode and even if he dont login to any user he can turn off the PC and the hibernation data will be lost
the simplest way is to give a BIOS Password
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 04-02-2008, 10:39 AM   #9 (permalink)
The Smaller Bang
thats what I said :roll:
Old 05-02-2008, 08:47 AM   #10 (permalink)
The Frozen Nova
casanova's Avatar
BTW, if u hibernate the PC and if someone else tries to turn off the comp, a message stating that users are connected to this compuer is displayed. You can let the other users know about this and ask them to hibernate in such a scenario.
casanova is offline
Hibernation Bluez gtoX Software Q&A 4 13-06-2006 12:16 AM
Hibernation Issues!!!! Andyiz QnA (read only) 34 14-12-2005 06:07 PM
hibernation prob...... sunny0384 QnA (read only) 4 20-09-2005 05:07 PM
Hibernation choudang QnA (read only) 10 15-09-2005 11:44 AM
- by chris
