Re: 64 Bit XP
Originally Posted by chicha
i have this doubt what is the performance improvement when i install a 64 bit XP or VISTA on my "AMD 4800+ X2".
will it be different from the current 32 bit XP i have?
You don't get performance increase using 64bit OS if you have 1gb ram in ur system, most software are still 32 bit.
To make the use of 64bit speed in real life you would need 64 bit software & over 4gb of ram, so each process can be assigned 2gb(max supported for 32 bit software) each, if the software are 64 bit then this limit will be enhanced further to 4-16gb ram each process.
32 bit softwares can max use 2gb ram of each, so a 64 bit will allow 2gb to each process (software) thus help you to multi task your machine without waiting.
