Lemme correct u Unknown, its Ctrl+J. No theres is no error. Save as Image command works, it opens destination folder but after clicking on Save nothing happens. Download StatusBar shows no activity neither does the inbuilt Downloads window. Its like if Downloading has been banned...
I was just checking the error console so found these errors so I think these are the causes. verify if thats the case and provide solution
Error: not well-formed
Source File: file:///C:/Documents%20and%20Settings/Rudra%20Pratap/Application%20Data/Mozilla/Firefox/Profiles/1diu8w3q.default/downloads.rdf
Line: 1, Column: 1
Source Code:
Error: [Exception... "ServiceManager::GetService returned failure code:" nsresult: "0x80570016 (NS_ERROR_XPC_GS_RETURNED_FAILURE)" location: "
JS frame :: chrome://downbar/content/downbaroverlay.
js :: downbarInit :: line 65" data: no]
Source File: chrome://downbar/content/downbaroverlay.
js
Line: 65
Error: db_gDownloadManager has no properties
js
Line: 1657
These are recurrently poppin' in the error console I think this is definitely the problem. As it says Download Manager has no properties set so how to correct it???
