Old 02-02-2008, 06:19 PM   #1 (permalink)
ComputerUser's Avatar
Exclamation Logon problem
This message comes up rarely during normal logon into XP but comes almost everytime I try to logon into SafeMode(also restarts if I try to go into this mode)-
"Windows cannot load the user's profile but has logged you on with the default profile for the system.
DETAIL - The process cannot access the file because it is being used by another process"
ComputerUser is offline
Old 02-02-2008, 06:32 PM   #2 (permalink)
ImAClown
Posts: n/a
Default Re: Logon problem
This is clearly the work of a virus!
Time to evacuate your house...
It can spread to humans
Did you enter the correct password? Windows XP has a hidden feature which im leaking now.. That is you can log in as root like how you do in Linux and you can obtain the source code... Top secret. Please dont tell it to all..
Old 02-02-2008, 07:20 PM   #3 (permalink)
i have same problem in xp login ..
error message is : make u sure log in. u enter domain name or password is wrong ... etc...
dsuresh is offline
Old 02-02-2008, 07:28 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
WTH !!
If u know solution to this problem, then only reply... Otherwise there is a separate Chit-Chat section for you.. :X
@Computer User,
Most possibly, this is Virus problem, try scanning ur computer with any GOOD Antivirus such as Kaspersky.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 02-02-2008, 09:25 PM   #5 (permalink)
Is my computer really infected? Gosh...But Avast! did not detect it...And I trust avast...anyways..better to scan up...
Old 02-02-2008, 10:57 PM   #6 (permalink)
Married!
Rahim's Avatar
Avast is getting weaker day by day
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 03-02-2008, 12:08 AM   #7 (permalink)
avira also weaker day by day
dsuresh is offline
logon and shutdown problem vikramkh Software Q&A 2 17-02-2006 04:46 PM
Win XP Logon Screen Problem d Software Q&A 3 01-07-2005 09:18 PM
- by chris
