Old 02-02-2008, 09:24 AM   #1 (permalink)
ashfahan's Avatar
Cool xbox360 three light problem
Hi there
I was using 360 for 6 months without any problem, but now i got stuck up.
my console often gives 3 red light problem.Sometimes i can overcome it by overheating it(By covering whole console with towel and running for 20 minutes.)
BUT it is not the permanent issue.....
NOW Dont tell me to contact microsoft or customercare as you all know....
Waiting for your help,
Thanks...
ashfahan is offline
Old 02-02-2008, 10:37 AM   #2 (permalink)
Maximum Fame
quadroplex780's Avatar
Default Re: xbox360 three light problem
U will have to open the consle and add some thermal paste
(Artic Cooling MX-2)to the gpu and cpu clean the dust.
If u ain't smart enough to do it ur self let an expert do it.
Search on the web for more.
ASUS P5N32E-SLI,XFX 8800GTS 640MB SLI,Intel Core 2 Duo E6600 Oced @3.01Ghz,Thermalright Ultra 120eXtreme,Corsair HX-620W PSU,250 GB Sata Seagate & Sony Sata AWG170S DVD writer,Asus Supreme FX Audio.
quadroplex780 is offline
Old 02-02-2008, 11:40 AM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
http://beingmanan.com
iMav is offline
Old 02-02-2008, 02:24 PM   #4 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Originally Posted by iMav View Post
He's using a Modded 360
I'm in safe waters here though , as i boght mine from an official dealer .
PS: but it seems my 360 isn't gonna die , coz i've been using it since october like 4-5 Hours a day and still it hasn' hanged even once .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 02-02-2008, 02:37 PM   #5 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
^ that RROD is more like a hype for unmodded consoles and in case of such problem microsoft support works great .the problem will have no perfect solution for modded consoles.u can try any local mechanic
Apple Macbook Pro 17 :cool:
nish_higher is offline
Hard Disk Light problem g_goyal2000 Hardware Q&A 4 19-11-2007 08:43 PM
n70 flash light problem arunks Buying Advice 2 27-07-2007 07:10 PM
buy which ps3 or xbox360 shivi4 Gamerz 61 05-06-2007 02:36 PM
Xbox360 ads on Mtv hbk549 Gamerz 3 09-09-2006 08:02 PM
- by chris
