Old 31-01-2008, 10:04 PM   #1 (permalink)
Default ntfs conversion?
guys i want to convert my c: drive (boot drive) from ntfs to fat32...
is thre any way...i dnt want to format it..
also...tell me wat are the pros and cons of both the formats.??
magneticme200 is offline
Old 31-01-2008, 10:18 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: ntfs conversion?
Just stick with NTFS unless you are using Win98 or older.!FAT32 won't support file transfers over 4 GB [Goodbye DVD movies.!], hard drives over 137 GB and isn't half as feature rich as NTFS.And there is no way I am aware of to do so without formatting the drive or using Partition Magic.
Life is as complicated as you say it is.
shady_inc is offline
Old 31-01-2008, 10:45 PM   #3 (permalink)
NTFS is a lot better. FAT32 doesn't support files bigger than 4GB.
Have a look at this: http://www.ntfs.com/ntfs_vs_fat.htm
Compare NTFS5 with the rest........
ico is offline
Old 31-01-2008, 11:06 PM   #4 (permalink)
johnjjx's Avatar
ntfs lot better......fat32 has single file size limit of 4gb.
johnjjx is offline
Old 31-01-2008, 11:21 PM   #5 (permalink)
dOm1naTOr's Avatar
FAT32 is recomented only if u wanna go back to WIN 98. And i think WIN 98 is obselete now.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 01-02-2008, 12:37 AM   #6 (permalink)
^^Correct
And if you need Win98 for your PC, consider installing it in Virtual Machine.
ico is offline
Old 01-02-2008, 08:57 AM   #7 (permalink)
ok...how do i convert my ntfs partition to ntfs5???
can i do that without formattin my data.??
also what is the way to install win98 with virtual machine..?
coz i hv some sftwrs that only run on win98 like tally4.5...
Old 01-02-2008, 09:38 AM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
why you want to run tally 4.5?
Upgrade!!
9 is out
gary4gar is offline
Old 01-02-2008, 05:02 PM   #9 (permalink)
If you had formatted your PC using Windows XP CD, you are on NTFS5 already. And if you want to use Tally 4.5, I'll suggest you to download and install DOSBox. It is available here: http://www.dosbox.com/download.php?main=1
For installing Windows 98 on virtual machine, you need to download & install Microsoft Virtual Machine 2007 (Available Here) and must have the Windows 98 CD........
ico is offline
Old 01-02-2008, 06:29 PM   #10 (permalink)
the link u gave is alright...bt the versions available of dosbox in thre aren't any in english....
i want one in english...
Upgrade!!
9 is out
actually bro some of my data is in tally 4.5 format...and i dnt knw how to get it converted to new format..
also thre is lan in my factory....and i hv some very old pcs thre which have only win98 installed...
and those pcs are used for data backup...
so i can't upgrade to new versions that very easily..!!
Last edited by magneticme200; 01-02-2008 at 06:29 PM. Reason: Automerged Doublepost
Old 01-02-2008, 06:36 PM   #11 (permalink)
Click here you'll get the English version........ http://prdownloads.sourceforge.net/d...r.exe?download
And BTW the one which is at the top Windows is the English language version on that page.
ico is offline
Old 02-02-2008, 06:29 PM   #12 (permalink)
i have dosbox now bro...bt hw do i run tally 4.5 with it now??
pls explain, if u can..?
Old 04-02-2008, 06:21 PM   #13 (permalink)
pls explain..???????????
Old 04-02-2008, 06:26 PM   #14 (permalink)
Ok..........I had lost this thread. Sorry for the delay.
1) Copy your Tally 4.5 files to a folder. Let me assume C:\tally
2) Now start DOSBox.
3) You'll see that your prompt is at Z:\. Now type mount c c:\tally. With this, your c:\tally drive will act as your C: in DOSBox.
4) Now go to C: and start your program.
Hope this helps you out.......
Edit: Go here to learn more about using DOSBox. C:\Program Files\DOSBox-0.72 and open README.txt
ico is offline
Old 11-02-2008, 06:04 PM   #15 (permalink)
Be urself--->
karina_got_it's Avatar
my prob is exactly opposite of this.. i have made my bootable partition as fat32. now i want to convert it into NTFS without losing my xp installation.
is there any way for that. mine is SATA hard disk
karina_got_it is offline
Old 11-02-2008, 06:07 PM   #16 (permalink)
1) Open Command prompt.....
2) Type this..... convert c: /fs:ntfs
This will convert C: drive to NTFS on the next restart.........
ico is offline
Old 11-02-2008, 07:40 PM   #17 (permalink)
^^Right.Use convert c: /fs:ntfs to convert c . The windows won't be able to convert partition to ntfs when windows is still running. So it will ask you to provide permission to do that at next reboot. Just grant the permission and at the next reboot you would get your drive converted to ntfs
ThinkFree is offline
Old 11-02-2008, 08:14 PM   #18 (permalink)
arun77574's Avatar
You can convert a FAT32 partition to NTFS without formatting but, no way from NTFS to FAT32 without formatting. Partition coversion is only forward compatible and not backward compatible.
Besides why do u wish to go for FAT32? NTFS is far far better than it. Its more secured and fast, supports more memory allocation than FAT32.
arun77574 is offline
Old 11-02-2008, 08:32 PM   #19 (permalink)
^^ We can convert NTFS to FAT32 using Paragon Partition Manager or Norton Partition Magic but whats the need of doing so? NTFS is better......
ico is offline
Need help in conversion.... FilledVoid QnA (read only) 10 22-08-2006 10:03 PM
Mp3 To mmf Conversion.....help! p_d5010 Mobiles and Tablets 3 13-09-2005 06:11 PM
ntfs reader not detecting my ntfs drive help expertno.1 QnA (read only) 3 24-05-2005 09:19 PM
Please help regarding MP3 to AAC conversion .. rohit_z2k QnA (read only) 12 09-03-2005 12:05 PM
Unable to mount all ntfs drives in fedora3.mount one ntfs, neerajvohra Open Source 1 06-02-2005 03:56 PM
- by chris
