Old 29-01-2008, 07:55 PM   #1 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Default Cleaning a motherboard??
hi ppl!!
I have this weird problem with my laptop, it doesn't boot.
now I won't go into details. But the problem has been persistent for the past few months and after trying everything I have narrowed down the problem to the mobo.
From what I have read around the internet it seems that dust or a bad solder is causing the problem. Some ppl can bend their mobo to fix their laptop temporaryly..
So help me guys. Any experience with cleaning and fixing mobos?
Shukriya!
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 30-01-2008, 11:38 PM   #2 (permalink)
chesss's Avatar
Default Re: cleaning 'unshorting' a motherboard??
bump
chesss is offline
Old 03-02-2008, 04:31 PM   #3 (permalink)
slugger's Avatar
y dont u just take ur lappy to the sevice centre 2 fix d problem
laptops dont have any user servicable parts [other than wiping the body with a clean cloth ]
y do u mean by that
slugger is offline
Old 03-02-2008, 11:26 PM   #4 (permalink)
chesss's Avatar
^well I read on the net that ppl with similar problem in desperation 'bent' their mobos (partially), which made theri laptop work again...
I have send the laptop to a service center today only..
chesss is offline
Old 04-02-2008, 12:15 AM   #5 (permalink)
will it b(l)end ?
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is online now
Old 04-02-2008, 01:24 AM   #6 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Originally Posted by T159 View Post
will it b(l)end ?
yes, but b(l)ending it to mend it will end it.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
DVD Cleaning? User Name QnA (read only) 6 22-12-2007 09:55 AM
Cleaning Fan Mohak QnA (read only) 1 12-11-2007 12:15 AM
CPU Cleaning Charan Hardware Q&A 18 17-10-2007 12:52 PM
DVD rom cleaning speedyguy Hardware Q&A 11 11-06-2006 04:18 PM
CLEANING MY W550i? BLITZ~KRIEG! Mobiles and Tablets 2 18-04-2006 09:26 AM
