| Forum |
#1 (permalink) |
Windows couldnot start because following file is missing or corrupt. \windows\system32\config\system I tried a repair installation. couldnot do it because it restarts in the middle of the process. I managed to boot in safe mode & cleared all start up programes. In System Startup & Recovery I cleared the Automatically restart dialogue box. Problem continues. AND this takes the cake: Sometimes when I am lucky ...It boots normally and works... atleast for 20-30minutes...Dont know what is happening. Help me please... I have a P4 3.6 GHz machine. OS- WINXP Pro SP2; HDD- 2, 20GB & 40 GB (Segate and Samsung) [1st one old & makes noise.. if that helps..] Last edited by SLIPKNOT; 30-01-2008 at 01:21 PM. |
#2 (permalink) |
Multicore Mutant
Please use normal font. Thanks.
Now for your problem , 3.6ghz whoah So you can start by cleaning your proccy and apply some good quality thermal paste. |
#4 (permalink) |
The Demun
yep xp acting up like that is most of the times a heating problem even i had the same problem. got a new fan fixed n did some cleaning it works jus fine afta dat
Ragnarok is a way of life ^_^ Join the wonderfully addictive world of ragnarok be a Rag addict the ultimate addiction in MMORPG |
#5 (permalink) |
left this forum longback
^check ur bios for acpi options.swap between ON or OFF to see which option fixes the restart issue
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#6 (permalink) |
GUNNING DOWN TEAMS
it can be case of ur hdd partion on which xp is installed going bad....install OS on diff partition....from good XP cd
The moment U stop learning ......u stop improving |
#7 (permalink) |
Does the PC restart in safe mode too? If yes then maybe your mobo is corrupted. Might be a hardware problem.
"I tried a repair installation. couldnot do it because it restarts in the middle of the process." According to this I feel it wouldn't be a software problem. For overheating I believe a error message comes sayint the last system shutdown was due to thermal overheating.Correct me if I am wrong.
Tips and Tricks that you never thought existed www.cooltechtrix.blogspot.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Restarting Windows Without Restarting Your BIOS (Vista or XP) | marulez | Technology News | 14 | 23-08-2007 01:19 AM |
| pc keeps restarting | a_tif | Software Q&A | 10 | 09-06-2007 04:23 PM |
| --> Quick launch toolbar vanished after restarting winXP | kool | Software Q&A | 7 | 16-04-2006 10:13 PM |
| Installing WinXP Pro over WinXP Home | rushab143 | Software Q&A | 9 | 12-02-2006 05:04 PM |
| One WinXP Inside another WinXP (No Multiboot). How ? | Kannan | Software Q&A | 5 | 16-06-2005 10:33 PM |
