Old 29-01-2008, 10:55 AM   #1 (permalink)
Exclamation Virtual Memory too low!!!
My friends laptop is experiencing a new sort of problem.
Whenever we install AVG antivirus, it works fine.But the moment we update it and restart the laptop, it becomes crappy slow and gives the warning "Virtual Memory too low".
I tried increasing the virtual memory from default value to range(744-148 8 ) i.e. double the default, but it doesnt help.
This happened even when we formatted the laptop and then again installed the antivirus.
The laptop has 256 mb ram, 1GHz processor, Toshiba Satellite series, 20 GB HDD.
visit:
http://skiewpoint.blogspot.com
http://aestheticblasphemy.blogspot.com
anshul is offline
Old 03-02-2008, 12:47 AM   #2 (permalink)
Default Re: Virtual Memory too low!!!
RAM memory is low ....
alternate : Right click on MYCOMPUTER > properties > advanced > performance SETTING > then select ADVANCED TAB > and change ur virtual memory not more than 512mb
dsuresh is offline
Old 03-02-2008, 12:52 AM   #3 (permalink)
damn busy...
utsav's Avatar
Increase ur virtual memory to 1GB and then see what happens.keep the task manager running and see how much memory the setup.exe is consuming
MSI GX660 with ATI 5870 ultimate gaming lappy
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 03-02-2008, 01:11 AM   #4 (permalink)
dOm1naTOr's Avatar
Set the min nd max at same value, like 1024MB so than windows will not have to increase/decrease size on need. And performance will be bit more than variable size
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-02-2008, 11:03 PM   #5 (permalink)
too much virtual memory is affect ur hard disk perfomance...
dsuresh is offline
Old 07-02-2008, 11:08 AM   #6 (permalink)
I had increased the virtual memory to 744(min)&1488(max).
But still it happened.
This too only when I installed an update of AVG free antivirus.
visit:
anshul is offline
Old 07-02-2008, 12:13 PM   #7 (permalink)
Wire muncher!
infra_red_dude's Avatar
1) System is fine for running XP + AVG
2) Set the system to use a "system managed swap file". In cases like yours that is the best option.
infra_red_dude is offline
What is virtual memory? pritish_kul2 QnA (read only) 3 25-06-2007 06:53 PM
Virtual Memory s18000rpm Software Q&A 18 16-02-2007 12:42 AM
virtual memory is low ? mkmkmk QnA (read only) 7 19-06-2006 09:03 PM
virtual memory 2 low samurai Hardware Q&A 3 22-01-2006 12:36 AM
virtual memory too low!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! alaap_anujan QnA (read only) 1 11-11-2005 06:10 PM
