| Forum |
#1 (permalink) |
i have scanned my computer for viruses. thr arent ne. whenever i open windows explorer the cpu usage shoots upto 100% showing explorer using ~99% and it remains so thereafter. also sometimes it (explorer) shoots upto 50% and remains like that. what may b the prob. also my computer is not restarting when i choose start>turnoff computer>restart. it hangs at "computer is shutting down". |
#2 (permalink) |
I Always Prefer 1080p
I recommend you to go to your BIOS and Under Advanced Tab-> Hardware Monitoring, check the Processor Temperature.
Nominal Temperature Fluctuation should be between 55-60 C. If its more than this then I would recommend you to change your thermal interface paste on the processor |
#8 (permalink) |
damn busy...
Bitdefender is crap.use nod
MSI GX660 with ATI 5870 Dell Studio 15(1555) 1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+ www.techjunkiez.com |
#9 (permalink) |
i argee, it's not a temperature issue, looks like a viral infection! use online scanners(they are fee and no installation in required)
http://security.symantec.com http://kaspersky.com/scanforvirus http://us.trendmicro.com there are plenty more out there..
Be not Thou far from me o Lord....o my strength....haste Thee to help me. |
#10 (permalink) |
@ utsav. actually i was hving nod32 sum times back. but came across this link http://anti-virus-software-review.toptenreviews.com/
then went for bitdefender. |
#11 (permalink) |
i again strongly suggest, try different antivirus. i have used norton 2001,2004,2008, Avast, AVG, Bitdefender, Kaspersky, and i can surely say that no single antivirus was fullproof. we cannot have more than one installed, but when we're sure we have an infection, we can try many of those.
#12 (permalink) |
checked with nod32 too. there are 3 virus on my comp as shown by bitdefender n nod32 but none of them cud clean or even remove them. the are in the system volume information which i m also not able to get even after knowing the full path name.
#14 (permalink) | |
damn busy...
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Problem regarding restart | Ankit Agrawal | Hardware Q&A | 2 | 20-07-2008 02:11 PM |
| Restart problem... | prasad_den | Hardware Q&A | 4 | 20-07-2008 01:58 PM |
| restart problem | suraj | QnA (read only) | 4 | 19-10-2007 03:22 PM |
| restart problem | slyfox | Software Q&A | 3 | 07-10-2007 05:34 PM |
| Restart Problem | ashu_dps | Software Q&A | 4 | 25-10-2006 04:10 PM |
