Old 12-02-2008, 10:53 PM   #31 (permalink)
pushkaraj's Avatar
Thumbs up Re: Virus!!! Help.
Originally Posted by Siddhartha_t69 View Post
And what if I had to undo changes?
Type this in the run box:
REG add HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer /v NoDriveTypeAutoRun /t REG_DWORD /d 0 /f
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 22-08-2008, 04:30 PM   #32 (permalink)
Default Re: Virus!!! Help.
I have bartpee autoboot cd ,thise cd have own operating. first to select boot from cd-rom in bios then run this cd you will see the winxp are started, then you go in each drive and remove System Volume Information and autorun.inf or remove virus file, then remove your cd and restart your pc
vishal687 is offline
Old 22-08-2008, 05:55 PM   #33 (permalink)
^Spam?
ThinkFree is offline
Old 22-08-2008, 05:58 PM   #34 (permalink)
AFK
thewisecrab's Avatar
I dont think so
But why bump a 6month old thread for BartPE?
And i think the prob got solved too
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 24-08-2008, 10:02 AM   #35 (permalink)
Problem solved 6 months ago.
Has been a long time though thanks for interest.
Might be useful to someone else.
Modern technology
Owes ecology
An apology.
~Alan M. Eddison
Siddhartha_t69 is offline
Old 24-08-2008, 10:16 AM   #36 (permalink)
Save the WORLD !!!
Kulz's Avatar
Try Logging into the SAFE MODE and if the task manager opens,then locate the mentioned files from the process explorer and delete them if they exist. Then navigate to WINDOWS\prefetch\ and check whether the said files exist or not. If they do,then delete them and restart your computer..
If this does not works(And even if it works), try installing an antivirus and a anti-spyware program and do a system scan. I would have preferred AVAST and SPYBOT-Search and Destroy..
Gud luck
Hey Hey!!! Didn't look at the previous entry... But had a nice tym posting it..........lol
Save the WORLD
Kulz is offline
Old 27-09-2008, 12:24 AM   #37 (permalink)
use AVG+spyware terminator(free)... havent had a virus in years... if all else fails use System Restore to restore ur system to a previous stable state...
omega12 is offline
Old 27-09-2008, 01:52 AM   #38 (permalink)
Wise Old Mouse
mrintech's Avatar
Scan your PC with a-squared and Spyware terminator: http://tech-baby.co.cc/2008/09/13/be...for-home-users
A good combination
- MrinTech :)
mrintech is offline
about a virus which attacked me,need guidence and giving info abt this virus-read mobileman Software Q&A 2 16-11-2007 12:43 PM
Virus problem, need online virus checking details-pls hava a read here. mobileman Software Q&A 2 14-04-2007 10:58 AM
latest mobile virus is : cardtrap virus anandk Mobiles and Tablets 5 06-10-2005 10:07 PM
mcafee virus scan 8.0 - problem updating virus definations infra_red_dude Software Q&A 3 26-06-2005 11:43 AM
VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT Writankar panja Software Q&A 9 19-09-2004 05:26 PM
- by chris
