Old 25-01-2008, 07:25 PM   #1 (permalink)
soumya's Avatar
Unhappy Photoshop CS3 Problem :(
Whenever I am trying to start photoshop, i am getting this error http://img140.imageshack.us/img140/9919/photomd7.jpg
It's driving me to nuts. I have the Visual C++ 2005 Redistributable Package (x86) installed though. So please help!
I blog at http://windowsxperience.wordpress.com/
soumya is offline
Old 25-01-2008, 07:40 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Photoshop CS3 Problem :(
Happens most definitely when you use a half-good patched loader for it.
No help on that, either do what you did in a better way or lighten your pockets.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 25-01-2008, 09:08 PM   #3 (permalink)
Elevating Humanity
The Conqueror's Avatar
Did u install the Visual C++ 2005 Redistributable Package after you installed Photoshop ? If this is the case, then try re-installing Adobe Photoshop
Regards,
The Conqueror
The Conqueror is offline
photoshop cs2 problem nil_3 QnA (read only) 2 09-04-2008 07:58 PM
adobe photoshop problem.please help. quan chi Software Q&A 12 08-11-2007 09:35 PM
Problem with Photoshop CS3. cyborg47 Software Q&A 5 06-02-2007 08:00 PM
photoshop keyboard shortcuts problem akitosforever QnA (read only) 2 20-10-2004 10:08 PM
