Old 24-01-2008, 07:20 PM   #1 (permalink)
Default startup problem
hey guys i have a prob...
my basic pc config is
pIV 2.4ghz
512 ddr1 ram
120gb hard disk
845 intel board
im uploading the screenshots of my startup and services window pls tell me what do, as with this config also my pc takes more than 4 mins to get ready fr use,
i have winxp sp2
pls help
im annoyed....i dnt think that my config is that very bad....
magneticme200 is offline
Old 24-01-2008, 07:57 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: startup problem
reg startups: disable all EXCEPT your antivirus.
you can also always start comodo fw when you visit the net. same goes for other progs too.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 24-01-2008, 10:11 PM   #3 (permalink)
wat does cftmon do??
is it necessary?
Old 24-01-2008, 11:14 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
is it necessary?
Part of microsoft office service.
ravi_9793 is offline
Old 25-01-2008, 05:02 AM   #5 (permalink)
Krazy_About_Technology's Avatar
ctfmon is a part of Windows XP also and it runs if Advance Text Services are on in 'regional and language options' (in vista, on Xp its in a diff cpl that i dont remember) control panel. In Win98 it was used to install with Office Xp. To turn it off, simple go to the appropriate applet and on the last tab, uncheck turn on advance text services. It'll be gone automatically.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 28-01-2008, 07:53 AM   #6 (permalink)
ive unchckd cftmon as well...bt still it takes almost the same time to boot..!!
Old 28-01-2008, 09:01 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
1) remove wallpaper from desktop.
2) Remove all external devices like printer, scanner, pen drive, digicam
3) start -->> control panel-->> sound and audio devices -->> sounds -->> from sound scheme options select No sound -->>Apply -->> ok
This can help you.
Old 31-01-2008, 02:05 PM   #8 (permalink)
Disabling ctfmon wont help much in reducing the startup time.
Try defragmenting your drives. Even if that doesn't help as a last resort reinstall your OS.
Tips and Tricks that you never thought existed www.cooltechtrix.blogspot.com
pramodv1988 is offline
Old 31-01-2008, 07:50 PM   #9 (permalink)
c: drive never can be fragmented i think...
and would fragmenting any othr drive effect the startup time??
coz startup is all related the the drive in which the os is installed..!
am i correct.??
Old 31-01-2008, 09:19 PM   #10 (permalink)
SivaChand
Is your system old?
Always look at what you have left.Never look at what you have lost
kpmsivachand is offline
Old 31-01-2008, 09:50 PM   #11 (permalink)
old as in...the number of days that hv passed since i bought my pc??
or...if u r askin bout the config...thn pls refer to my first post..i hv mentioned basic config thre..!
Old 04-02-2008, 06:22 PM   #12 (permalink)
Originally Posted by kpmsivachand View Post
Is your system old?
Old 05-02-2008, 01:33 AM   #13 (permalink)
C drive can get fragmented !!
first use CCleaner (http://www.ccleaner.com/) to remove unnecessary, temp files etc. then defragment ur C drive....
if nothing helps, format ur C:
A weird thing about humans is we work till we\'re sick to get a fortune, then pay a fortune to get well again.
The road to success is always under construction.
harmik is offline
Startup Problem visujinu Hardware Q&A 8 28-12-2007 08:02 PM
Help me... Getting startup problem jyoti.mallick02 Software Q&A 7 08-12-2007 07:42 PM
System Startup Problem............ satyamy QnA (read only) 3 13-02-2007 03:10 PM
startup problem sujeet2555 QnA (read only) 1 28-07-2005 05:18 PM
- by chris
