Old 22-01-2008, 07:04 PM   #1 (permalink)
pushkaraj's Avatar
Exclamation Hidden system driver
There is a hidden system driver as detected by avg anti-rootkit. i hav attached the screenshot. Should i delete the system driver or should i leave as it is?
I also did a scan by hijackthis but did not find any such suspicious file. i have attached its log.
A full system scan by mcafee also did not reveal any such file. However some days back i had done a scan by avg anti-spyware and had found a similar hidden system driver file. At that time i had fixed it thru avg. Now there is again another file. Should i delete it?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 23-01-2008, 02:55 PM   #2 (permalink)
pushkaraj's Avatar
Default Re: Hidden system driver
Please help guys.............
Old 23-01-2008, 03:21 PM   #3 (permalink)
Create a new system restore point and delete that file. If something wrong happens use the created system restore point to revert otherwise believe that AVG anti rootkit is not wrong
ThinkFree is offline
Old 23-01-2008, 03:28 PM   #4 (permalink)
pushkaraj's Avatar
Thumbs up Re: Hidden system driver
^^^omg, why didnt dat strike me - SYSTEM RESTORE
@asnvin, thanx man
will try that.
Old 23-01-2008, 04:02 PM   #5 (permalink)
adi007's Avatar
i suggest u delete the file coz i googled the file name ahu13p95.SYS and found no results ..if it were a windows driver file then it would have given some results..
don't know whether i am right or not?
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 23-01-2008, 04:26 PM   #6 (permalink)
pushkaraj's Avatar
Angry Re: Hidden system driver
^^^Thanx for ur suggestion. i havent deleted ahu13p95.SYS coz it is not there in its location
I again scanned from avg anti-rootkit and hav attached a screenshot of the result. As seen in the screenshot, there is a new file detected. i searched for that file in my computer and the search returned zero results
i hav already scanned my system with mcafee and avg anti-spyware and there are no threats detected.
Old 24-01-2008, 11:36 AM   #7 (permalink)
adi007's Avatar
^^The files are there but it's hidden as well as behaving like system files..
first change the folder options..
via view>>Folder Options..
enable show hidden files and folders,show file extensions,show system files option..
After doing this u will find the file...
don't search the file navigate to that location itself and delete the file if u are sure that it's not system driver file...
U could search for that file too but searching will not search hidden and system files by default...in order to do that search as usual and in the middle stop the search select ..check include system and hidden files option and select expanded... and click search..(sorry if i'm wrong in some steps coz i have no internet connection in my home..and in our college there is linux so it's difficult to express how to do...)
and BTW i googled the file ajv1ozz5.sys and found no results..so there is greater possibility that it might not be a system driver file..
adi007 is offline
Old 24-01-2008, 10:50 PM   #8 (permalink)
pushkaraj's Avatar
^^ Thanx for ur reply man.
i searched all the drives on my computer even after checking to search hidden and system files. couldn't get tat file. also now if i scan thru avg anti-rootkit, it again shows me a new file which is again ABSENT in my system.
Probably there is some problem with the avg anti-rootkit
Where are my hidden files ???????????? jayanbhm QnA (read only) 1 06-06-2007 01:09 PM
Hidden and Confusion cooldip10 Gamerz 3 23-03-2006 10:39 PM
Wi***w$ XP HIDDEN sara2002 QnA (read only) 14 21-10-2004 02:43 AM
- by chris
