Old 22-01-2008, 11:26 AM   #1 (permalink)
ashfahan's Avatar
Default Auto dial broadband
Sir
I am using BSNL home 900+ plan.
I want that whenever i start my computer , it should autometically connect to net.I dont want to press dial everytime( As i m using utorrent and at night sometimes my comp restart or the connection disconnect).
OR is there any setting in utorrent to autodial the broadband dialer.
Please help.
Originally Posted by ashfahan View Post
Sir
Please help.
Well i found the answer myself!!
I put the dialup shortcut on startup and unchecked the option "Prompt for user name and password" from dialup properties.
Well thanks myself....
ashfahan is offline
Old 22-01-2008, 02:56 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Auto dial broadband
Another easy way is ......... use of PPPoE protocol.
You can configuare your DSL modem to PPoE protocol, to enable always ON connection.
Here is how you can configuare to PPoE:
http://www.techhunt.org/node/52
ravi_9793 is offline
Old 22-01-2008, 09:04 PM   #3 (permalink)
M$™ Certified Spammer
entrana's Avatar
how bout just create a connection, right click its properties and there is a option for it not to ask password and username. so when u double click it , it just connects to the net
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 22-01-2008, 09:44 PM   #4 (permalink)
Proud to be Linux
abhinandh's Avatar
i use a small useful tool called reconnect.it starts at system startup dials the connection.it even redials if line dropped and there is a sheduler to shutdown pc.i use it to automate my h500 dataone.get it free at
http://www.sharewareconnection.com/reconnect.htm
abhinandh is offline
Old 23-01-2008, 06:50 AM   #5 (permalink)
Smile Re: Auto dial broadband
I use advance task scheduler....I rate it one of the best
I can dial ur connection/disconnect connection/launch an app/shutdown the pc
for more info logon to
http://www.advscheduler.com/
'Veni, Vidi, Velcro\' - I came, I saw, I stuck around.
hyde is offline
Old 24-01-2008, 05:03 AM   #6 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Best way is to auto configure the modem with Login Credentials so that we wont have a problem even if we reinstall the OS
techtronic is offline
Old 21-06-2008, 12:18 PM   #7 (permalink)
thanks a lot....this software just made my day
apoorva84 is offline
Auto Dial of Bsnl Broadband hmmmmmmmmmmmmm Broadband and DTH 4 02-09-2007 12:17 PM
Dataone Auto Dial vineetrocks2005 Broadband and DTH 3 31-08-2006 02:43 PM
Broadband with Dial-up's zero Broadband and DTH 20 30-06-2006 12:26 AM
dial up or broadband bkpeerless Broadband and DTH 4 12-03-2006 08:12 PM
Unable to send mail thru dial-up after broadband rswain Broadband and DTH 6 08-06-2005 12:36 PM
