Old 21-01-2008, 05:45 PM   #1 (permalink)
Question dll problem in removing flash drive
Whenever I want to disconnect the Flash Drive from my computer and click on 'safely remove hardware' I get the following message :
--An exception occured while trying to run "shell32.dll, Control_RunDLL hotplug.dll"--
Then microsoft's error reporting dialogue comes up. I have sent the error report too, by no reply. please help.
Will it damage the PC or flash drive if I remove the flash drive without the proper procedure?
psnegi26136 is offline
Old 22-01-2008, 07:54 PM   #2 (permalink)
Default Re: dll problem in removing flash drive
Removing the drive without using the safely remove hardware option may be harmful for your pen drive. Until you find any other solution, you can remove your drive after shutting down your computer
ThinkFree is offline
JET FLASH Usb drive problem mrbgupta Hardware Q&A 2 30-11-2007 10:55 AM
Toshiba 8 GB USB 2.0 flash drive giving problem sanju Hardware Q&A 3 25-11-2007 11:48 AM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Flash Drive problem? vinith98 Hardware Q&A 3 31-01-2007 06:20 PM
Removing a CD-ROM drive suresh_mask QnA (read only) 3 01-05-2005 08:15 PM
