Old 21-01-2008, 04:33 PM   #1 (permalink)
ComputerUser's Avatar
Default Virtual Box Problem (???)
I created an XP cd using nlite.When I install it in Virtual Box, it copies all the files in the text-mode based installation and when it restarts it jumps to the installation of XP!!! It does not ask for any key,regional options, etc,!!!It doesn't collect any information at all,but still continues with the installation.I didn't choose unattended installation in nlite. Why is this happening?Does it happens only in virtual machines? And please do tell me if this will also happen if I really install that XP in my hard disk.
ComputerUser is offline
Old 22-01-2008, 11:54 AM   #2 (permalink)
adi007's Avatar
Default Re: Virtual Box Problem (???)
^^if it happens in the virtual machines it will sure happen in real ....
u mush have changed some setting..
now what u do is create a iso file by using nlite then test it in virtual box...and if all works then only burn the cd..
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 22-01-2008, 04:45 PM   #3 (permalink)
It is not working.
Old 22-01-2008, 04:47 PM   #4 (permalink)
adi007's Avatar
^^explain
adi007 is offline
Old 23-01-2008, 03:59 PM   #5 (permalink)
I again checked up everything and made another image file and tried it but the same problem!!!
Old 23-01-2008, 07:16 PM   #6 (permalink)
Elevating Humanity
The Conqueror's Avatar
Did u complete the installation ?
It asked me the CD key after it finished installing half
Regards,
The Conqueror
The Conqueror is offline
Old 24-01-2008, 04:49 PM   #7 (permalink)
I stopped when i saw it did not ask anything.But what's the problem?
virtual memory problem!!!!!!!! kouki Software Q&A 15 14-08-2007 08:28 PM
!! Virtual Dub Problem - Urgent Dipen01 Software Q&A 8 17-05-2007 10:11 PM
Virtual Dub Problem Maverick340 QnA (read only) 10 14-11-2005 10:34 PM
