Old 14-01-2008, 12:16 PM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default double clicking on E: open's E: in another window
Hi
When I Double click on E: in My Computer it open's E: in another window.
The rule is it must open on same window.
When I right click on E: the first option it display's is Open(O) and then Autoplay, Search, Open, Explore.
There r 3 drives on my hard disk. C: D: E:
This problem occurs only on c & e drives.
Please help guys, what is this happening?
Blogging at:
Technostarry
saqib_khan is offline
Old 14-01-2008, 01:23 PM   #2 (permalink)
slugger's Avatar
Default Re: double clicking on E: open's E: in another window
in Windows Exlorer
Tools->Folder Option
In d General tab, select Open each folder in the same window option
c if it helps
slugger is offline
Old 14-01-2008, 03:19 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
Yes "Open each folder in the same window" option is already selected.
But, it doesn't help.
Anymore suggestion's. ????
Blogging at:
Technostarry
Old 14-01-2008, 03:39 PM   #4 (permalink)
Some sort of Autorun.ini file has been created by a Trojan. Delete it, it'll be in your Root directory (C:, D:, E: ). Go to Folder Options and enable viewing of Hidden Files and Folders and also uncheck Hide Protected Hidden Files ...... and then Delete the Autorun.ini file and have a Restart.
Same problem is being faced here: Garbage character but here the Autorun.ini has modified the Context Menu options........
ico is offline
Old 14-01-2008, 05:53 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
http://www.techhunt.org/node/11
ravi_9793 is offline
Old 14-01-2008, 05:59 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
Goto Folder Options, there click on "show hidden files and folders" and then uncheck "Hide protected OS files"
Goto the drive and delete the autorun.inf.
Then scan your computer to remove the worm
http://twitter.com/akshayms
nvidia is offline
Old 14-01-2008, 07:41 PM   #7 (permalink)
New
New's Avatar
Go to [Windows] FreQuently AsKed ProBlems WITH SoluTions...
New is offline
Old 15-01-2008, 10:00 AM   #8 (permalink)
Download And Run This
http://www.techsupportforum.com/sect...isinfector.exe
devil_himself is offline
Old 15-01-2008, 02:01 PM   #9 (permalink)
I M A *STAR*
saqib_khan's Avatar
Thanks to u all.
I solved my problem
Blogging at:
Technostarry
Old 15-01-2008, 07:54 PM   #10 (permalink)
you're welcome......
ico is offline
double clicking D drive ajit.naik Software Q&A 10 23-11-2007 09:22 AM
c drive not opening on double clicking kooabs03 Software Q&A 16 17-11-2007 06:09 PM
Double clicking on drive opens search! DizitalNovice QnA (read only) 6 24-05-2007 12:01 AM
Help me pls.. Application doesnt start after double clicking abhi99_iitg Software Q&A 3 23-09-2006 04:53 PM
