Old 13-01-2008, 08:46 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
ramsingh's Avatar
Default best software to monitor DATAONE usage..
i am sharing dataone with 2 other friends... we are using Bandwith monitor for checking usagell but it is showing error..like 1.22 GB for me in 2 days ..etc... wht software is best to check dataone usage...
nd is there any way by which i can monitor or keep track of my other two friends usaqge..??
ramsingh is offline
Old 13-01-2008, 08:54 PM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: best software to monitor DATAONE usage..
If you are using Firefox, try Datafox
http://twitter.com/akshayms
nvidia is offline
Old 13-01-2008, 09:05 PM   #3 (permalink)
ramsingh's Avatar
i am a new user.. so i dnt know whether it will work ?? nd the site is now working. for datafox..
ramsingh is offline
Old 13-01-2008, 09:15 PM   #4 (permalink)
-----ATi-----
nvidia's Avatar
It will work if you have Firefox. Just install it and give it a try
what?
nvidia is offline
Old 13-01-2008, 09:20 PM   #5 (permalink)
ramsingh's Avatar
the link that u hav given me for datafox is not working..
ramsingh is offline
Old 13-01-2008, 10:25 PM   #6 (permalink)
I Always Prefer 1080p
techtronic's Avatar
IMHO, Dataone Usage Finder is the best. I have been using it from August 2007 with no problems.
URL : http://duf.sourceforge.net/
techtronic is offline
Old 14-01-2008, 03:48 PM   #7 (permalink)
ramsingh's Avatar
plz suggest a good data transfer tracker software..
ramsingh is offline
Old 15-01-2008, 12:03 PM   #8 (permalink)
dataone bandwidth usage finder from shaplus.com
contactram is offline
Old 16-01-2008, 02:26 PM   #9 (permalink)
i have been using DU meter and its pretty good................ would like to let u know that its not a freeware..........
venomspree is offline
Old 16-01-2008, 02:37 PM   #10 (permalink)
vaibhavtek
Posts: n/a
Old 16-01-2008, 05:08 PM   #11 (permalink)
The Researcher
For new users none of the above will work
Ramakrishnan is offline
Old 16-01-2008, 05:17 PM   #12 (permalink)
-----ATi-----
nvidia's Avatar
@vaibhavtek: Are you copy pasting the same content from other posts? Look at post #6... Only one line missing
nvidia is offline
Old 16-01-2008, 10:03 PM   #13 (permalink)
+1 for Datafox. It is really good if you are a Firefox user.
http://www.thegoan.com/datafox/
ico is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/78163-best-software-monitor-dataone-usage.html
Thread ShaPlus Dataone usage finder 2.8 | Digit Forum | BoardReader This thread Refback 27-09-2010 06:28 PM
not able to see dataone usage. abhinandh Broadband and DTH 9 11-01-2008 06:15 PM
doubt with dataone usage abinesh Software Q&A 11 31-05-2007 10:09 PM
Dataone usage & PC scheduling webgenius Broadband and DTH 2 08-03-2007 05:57 PM
How 2 Know The Bsnl Dataone Usage kuldeep bhardwaj Broadband and DTH 3 04-05-2006 05:25 PM
