Old 22-08-2004, 01:59 PM   #1 (permalink)
Default HeadFones With MicroFone Problems.....
I bought a headphone with a microphone facility.
the problem is, the left speaker dosent produce any sound.
bought it from a reputed dealer i've known from ages
I am not able 2 record voice, do i need 2 alter any multimedia settings 4 this ???
i just plugged it in the comp and well, Its really aint workin the way it should.
Kindly help
It says it has been designed 2 work 4 win9X n i work on 98se.
Death keeps smiling at us all the time, all we can do is Smile back.
FasTrack is offline
Old 22-08-2004, 04:04 PM   #2 (permalink)
Tht happens in my headphone too-no sound in left ear-so i havent put it all the way in abt a m or so out(the pin in thecpu)-try moving it in and out till uget in both ears-is a silly method but works for me
If u think u r right...u r a bad thinker!
Jatin_T is offline
Old 22-08-2004, 04:22 PM   #3 (permalink)
For recording voice, are you sure you plugged the microphone plug into the proper port? Also try updating your sound card drivers.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 22-08-2004, 06:25 PM   #4 (permalink)
I'll try
FasTrack is offline
Old 28-08-2004, 12:06 PM   #5 (permalink)
King of my own Castle
freshseasons's Avatar
I think its one of the hardware things..never heard driver problems related with this ... First i have heard this kind of things happen in Walkman...when the headphone were good but the out put came only through one speaker...Latter found out the walkman was mono and being stereo headphone i had just to losen up the socket just a tad....anyway are u using onboard sound ????
freshseasons is online now
- by Charley
- by tv6952
- by soumya
