Old 10-01-2008, 12:15 AM   #1 (permalink)
Default how to access data on pen drive without infection?
I have a slight bit of a problem. There is this bug avpo.exe in a flash drive with me. Now I need to access the data on the pen drive. And copy it on to my hard disk. But the first time I accessed the pen drive I got the avpo.exe bug.
So is there any way i can access the pen drive's data without causing the virus infection.
I think double clicking on the pen drive's icon on My Computer would surely activate it.
But if I right click and choose Explore or I key in the Prompt of the pen drive's location in the Address bar. Would that also infect my computer?
Really need to access the data so if there is any way to do so please help without getting infected by avpo.exe.
PS: and scanning the pen drive is no use.The 1st time I did no viruses were shown but still got infected. I am using Avast Antivirus with the latest updates. Removal of avpo.exe is quite cumbersome hence I don't want to do it again.
anubhavj1 is offline
Old 10-01-2008, 12:23 AM   #2 (permalink)
slugger's Avatar
Default Re: how to access data on pen drive without infection?
Originally Posted by anubhavj1 View Post
IPS: and scanning the pen drive is no use.The 1st time I did no viruses were shown but still got infected. I am using Avast Antivirus with the latest updates.
it just means dat Avast is unable to detect it
switch over 2 AVG Anti-Virus Free Edition and scan d drive
if u not ready to replace Avast, den use either ClamWin or even an online can to detect and remove it
slugger is offline
Old 10-01-2008, 12:31 AM   #3 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
or download TweakUi and der is a option to disable autorun in removable drives.
Then u can right click the drive and select "Explore" to open the pen drive,before doing that make sure autorun is off
http://www.annoyances.org/exec/show/tweakui
if u can download kav 6 trial version and do a scan it will be a better option
http://www.kaspersky.com/
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 10-01-2008, 12:35 AM   #4 (permalink)
left this forum longback
praka123's Avatar
or try a linux livecd(ubuntu or knoppix) and mount ur usb(automounted);then check and delete suspicious files.
even better there is bitdefender livecd(linux based),which can scan ur system,usb drives etc
praka123 is offline
Old 10-01-2008, 01:07 AM   #5 (permalink)
 Macboy
goobimama's Avatar
Or just take that pen drive to someone who has a mac (or Linux)
I'm like a bird... :)
goobimama is offline
Old 10-01-2008, 01:25 AM   #6 (permalink)
dOm1naTOr's Avatar
boot from any linux live discs nd then copy the contents u wanted.
There are even fully functional Windows Live discs images found on net. They are gr8 nd best for removing virus. They have more than 6 best AV preinstalled.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 10-01-2008, 03:41 AM   #7 (permalink)
Loading . . . please d'nt
CINTEL ENTRINO's Avatar
off topic query...
i have a sandisk cruzer drive[with U3] 2 GB pen drive.
the problem is when i try to plug it in my Philips DVD player[3166X]...
it shows "device not supported"... though my memory card reader n mp3 player work fine....
is there any way i can uninstall the U3 features so that it becomes a mass storage device ??
the main partition is formatted in FAT32 format...
CINTEL ENTRINO is offline
Old 10-01-2008, 08:14 AM   #8 (permalink)
slugger's Avatar
U3 Launchpad Removal Tool
altho i suggest dat u first try disabling u3 functionality and c wat happens b4 completley removing it
Disable Auto-Run and Auto-Play of U3 Smart Drives Launchpad
slugger is offline
Old 11-01-2008, 04:20 AM   #9 (permalink)
thnx... will chk it
To use MS ACCESS (XP) data file in vb6 project anilvc31 Software Q&A 1 15-05-2007 03:09 PM
Access Bsnl Data One Wirelesly bhutbhut Hardware Q&A 2 01-02-2007 08:41 PM
SQL VB6 connectivity Data access error CyCo Software Q&A 1 06-10-2006 11:03 AM
Microsoft Data Access & Comnponents (MDAC) The Incredible Software Q&A 6 02-06-2005 07:21 PM
