Re: Need Help
Empty any one partition and format it as ext3. Take about 1gb of space split it and format it as ext3. then insert the dvd, boot from it and follow the instructions.
Empty any one partition and format it as ext3. Take about 1gb of space split it and format it as swap. then insert the dvd, boot from it and follow the instructions.
Reason: Automerged Doublepost
