Old 07-01-2008, 09:25 AM   #1 (permalink)
Default problem with svchost.exe
i have three instances of svchost.exe in my taskmanager.. i dont know if this is the cause for the problem.. its that my connection gets disconnected, and it wont redial,it shows svchost.exe error.. i use dataone home500 plan.. so i've scheduled it to connect to net at 2am and start downloading.. i had no probs earlier..recently,after sometime,the connection gets disconnected and the above error occurs..any1 plz help me
balavinayak is offline
Old 07-01-2008, 10:25 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: problem with svchost.exe
make sure it is SVCHOST.EXE
you can have more than one SVCHOST.EXE. Each Svchost.exe session can contain a group of services.
svchost.exe is a generic host process name for services that run from .dll files.
To view the list of services that are running in svchost:
start-->>run-->>type CMD-->>OK-->> Type Tasklist /SVC, and then press ENTER.
ravi_9793 is offline
Old 07-01-2008, 01:13 PM   #3 (permalink)
piyush gupta's Avatar
make sure it should be svchost
and it must be a system process..
if its owner is logged in user..that means there is something wrong with your system
for better safety u can also run a hijackThis test and post your log file so that someone can help u
piyush gupta is offline
Old 23-03-2008, 06:28 PM   #4 (permalink)
4U
karan4's Avatar
Lightbulb Re: problem with svchost.exe
the best way to be relieved by these malwares is-
1> open your task manager
2>check out if these processes are running
smss.exe
killer.exe
svchost.exe(three times)
lsass.exe
3>just download these useful antivirus and registry cleaners
a>spyware terminator 2.1(http://www.spywareterminator.com
b>regcure 1.5(i've downloaded it from limewire)
c>spybot search and destroy(http://www.freedownloadsspace.com
these are for permanent security from these viruses
or
you can simply download these top-rated antivirus
1 avira antivir with utilities(
http://www.free-av.com)
2 kaspersky 7(http://www.freedownloadsplace.com
i hope you will send me a positive reply
karan4 is offline
Svchost Problem kkg_mjh Software Q&A 2 23-04-2007 08:50 PM
Win2k svchost problem sknowonweb Software Q&A 1 16-01-2006 09:01 PM
svchost & Kaspersky Problem ... plz help Hijackthis attached talrejaharish QnA (read only) 7 07-03-2005 02:31 PM
SVCHOST.EXE process magic problem ArZuNeOs QnA (read only) 4 17-01-2005 09:49 PM
