Old 07-01-2008, 12:06 AM   #1 (permalink)
ToxicSerpentz's Avatar
Default Problems with Flashget
Windows XP Pro SP2
I use Flashget for downloading Bittorrent files. Use a Reliance Netconnect wireless internet connection. Before i formatted my pc, i used to get excellent speeds on both bittorrent and http downloads. Now i don't get connected to any tracker and speeds are drastically reduced. My http downloads are still fast enough(talking about 20-30 kbps, considering i live pretty close to a tower).
Also,how can i manually dedicate all my bandwidth to downloading and keep my connection alive at the same time?
Thanks.
ToxicSerpentz is offline
Old 07-01-2008, 02:07 AM   #2 (permalink)
dattebayo
anispace's Avatar
Default Re: Problems with Flashget
flashget for torrents? use it only for direct downloads.. for torrents u would be better off using azureus or utorrent. almost all trackers recommend both of them. Also u can allocate manual download speeds so as to keep ur conn active for browsing.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 07-01-2008, 02:13 PM   #3 (permalink)
I have already tried utorrent and azureus but i seem to get best speeds with flashget. Atleast that was so.
Or perhaps u cud tell me the best way to optimize my wireless connection.
Also i wanted to know how to dedicate all my bandwidth to downloading?
Old 07-01-2008, 02:25 PM   #4 (permalink)
Deadman Walking
Batistabomb's Avatar
at the very first use of internet after formatting, what's the speed ? same deducted or recently you observed speed reduced
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 07-01-2008, 02:32 PM   #5 (permalink)
Here Since 2003
Indyan's Avatar
Check that the port you are using is open and is being forwarded.
Indyan is offline
Old 07-01-2008, 02:40 PM   #6 (permalink)
Google Bot
Pathik's Avatar
Which firewall are u using?
Pathik is offline
Old 07-01-2008, 07:26 PM   #7 (permalink)
To Pathik,
I use ZoneAlarm Internet Security Suite.
To Indyan,
Not sure how to check port is open and being forwarded.
Perhaps it's related to the fact that i can't download from referrers as well.
To Batistabomb,
Speeds have reduced dramatically with regard to torrents.
HTTP Downloads are so so.
Flashget problem SE><IE QnA (read only) 4 27-03-2009 07:31 PM
Flashget query dreamcatcher Software Q&A 3 16-11-2007 06:12 PM
Flashget ComputerUser Software Q&A 5 17-05-2007 03:49 PM
Help me with FlashGet, please! aryayush Software Q&A 4 02-06-2006 08:40 PM
