Old 06-01-2008, 07:34 PM   #1 (permalink)
Loading . . . please d'nt
CINTEL ENTRINO's Avatar
Default lost saved passwords.... help !
i have lost all my passwords... saved in firefox password manager....
although ff works perfectly fine.... n bookmarks are also secure...
but password manager does not show any saved passwords.
i am using firefox version 2.0.0.11
pls help me guys.....
anyone ?
Last edited by CINTEL ENTRINO; 06-01-2008 at 07:34 PM. Reason: Automerged Doublepost
CINTEL ENTRINO is offline
Old 07-01-2008, 06:39 PM   #2 (permalink)
Cool Re: lost saved passwords.... help !
Whenever you
1. Updated Firefox to a newer version OR
2. Used this Step: Tools->Options->Security->Show Passwords->Remove All OR
3. Pressed Ctrl+Shift+Del & then Had Selected "Saved Passwords" in that & pressed "Clear Private Data" button
I am sorry to say, but those cannot be recovered. .Guys, Correct me if I am wrong.
I think from next time you need to use this addon for Firefox for Exporting/Importing your Saved Passwords:
Password Exporter
Chk this link for more info abt Password Exporter:
http://www.mydigitallife.info/2007/1...ird-and-flock/
Also, you know that in Firefox, anyone can view your saved passwords.
So set a Master Password for Viewing the Saved passwords.
You can do it like this:
Tools->Options->Security Tab ->Tick Use Master Password
Enter a Master Password & don't forget this password. If you forget this, then you are back to square one.
shadow2get is offline
Old 07-01-2008, 06:42 PM   #3 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: lost saved passwords.... help !
you cleared the entire cache, so howzz it get back again, once try system restore
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 07-01-2008, 06:48 PM   #4 (permalink)
Smile Re: lost saved passwords.... help !
Originally Posted by shadow2get View Post
Whenever you
Password Exporter
no man....
i did'nt do any of the 3 things......
it happened all of of a sudden....
but im trying to retrieve them 1 by 1 through my mails. thnx a lot for the addon though
n pls tell me how to modify prefs.js file ... ?
Old 07-01-2008, 07:04 PM   #5 (permalink)
Originally Posted by CINTEL ENTRINO View Post
no man....
AFAIK, I really don't know how it could have got lost without doing any of the 3 methods said above. Will let u know if I find it out.
I am assuming you are trying to modify your settings for Firefox.
Firefox recommends you to use about:config instead of directly modifying the prefs.js file.
Anyway, hope you know what you are doing. Check these links:
http://www.mozilla.org/support/firefox/edit
http://www.techspot.com/guides/44-fi...de/page10.html
http://www.mozilla.org/catalog/end-u...riefprefs.html
BTW, you can modify the prefs.js file by
1. Right Click & then Select Edit. OR
2. Open the file in Notepad or any Text Editor.
Hopefully that helps.
Old 07-01-2008, 07:15 PM   #6 (permalink)
i did delete the browsing history.... but that isn't the reason right ?
b'coz i only had "browsing history" checked in "clear private data" option....
n i hav safely exported 19 passwords in xml format through
password exporter....
thanks a lot for ur help...
Old 07-01-2008, 07:26 PM   #7 (permalink)
Thumbs up Re: lost saved passwords.... help !
The only other reason I think of is Someone else must have used that option & not you. It may have been cleared before you had even noticed.
Or You yourself may have used it earlier.
HOWTO - Recover lost Windows 2000/XP/2003 Admin Passwords enoonmai Tutorials 13 07-09-2010 05:11 PM
I have lost My 42 GBHow can I gain My lost space. Kaushal Hiwarkar Software Q&A 4 20-02-2007 03:14 PM
recover lost Windows XP passwords ! anandk Software Q&A 15 11-02-2007 10:54 AM
backing up passwords saved in Firefox bizzare_blue Open Source 5 25-10-2006 04:29 PM
passwords in win xp mahendran Software Q&A 1 08-12-2004 07:04 PM
