Old 05-01-2008, 06:27 PM   #1 (permalink)
Tanmay's Avatar
Default Vista/Ubuntu Dual Booting Help
So I already have Vista-XP and Ubuntu installed. For now GRUB loads by default.
So what I want is to make Vista's Bootloader the default Boot Manager which gives me 3 Options ::: Vista , Previous OS and Ubuntu.
I've heard its simple with BCDEdit.
So can anyone gimme a step by step procedure to do that ?
My Apple Blog : www.TheAppleDaily.com
My Microsoft Blog : www.MicrosoftDaily.com
Tanmay is offline
Old 05-01-2008, 07:09 PM   #2 (permalink)
a_tif's Avatar
Default Re: Vista/Ubuntu Dual Booting Help
u would first need to restore the vista boot manager
to do this u need vista bootable dvd
boot the dvd n find the option to repair boot
this will restore vista boot manager
now only vista will be bootable
in vista now u can use bcdedit or easybcd to create entries for xp , ubuntu
a_tif is offline
Old 05-01-2008, 07:28 PM   #3 (permalink)
Torrent Lover :)
akshaykapoor_3's Avatar
^^^ Even m facing the same prob...
rite nw i hav XP Vista nd Ubuntu installed
bt i dont get d option to boot into ubuntu at startup...hw do i get that working ? at present m able to boot into vista nd xp..
akshaykapoor_3 is offline
Old 05-01-2008, 07:58 PM   #4 (permalink)
Tanmay's Avatar
Err..bro I already know that ! I'm asking how ? I could use Google, but then whats the use of Forums ?
I could really appreciate a Step by Step Procedure, and I guess it'll help many other people too
Tanmay is offline
Old 05-01-2008, 08:13 PM   #5 (permalink)
a_tif's Avatar
u can start with the first step of restoring the vista boot manager
it is quite straight forward
take a look at this for adding entries using easy bcd
http://neosmart.net/wiki/display/EBC...Remove+Entries
a_tif is offline
Old 06-01-2008, 10:14 PM   #6 (permalink)
Tanmay's Avatar
I still need a Step by Step Procedure like a Tutorial for N00bs Anyone out there who can do that ?
Tanmay is offline
Old 06-01-2008, 10:52 PM   #7 (permalink)
in search of myself
CadCrazy's Avatar
Go Here
http://apcmag.com/dualboot
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 07-01-2008, 08:01 AM   #8 (permalink)
Tanmay's Avatar
Thanks but I already had Googled The above guide too concludes with :
If instead of GRUB you want Vista's bootloader to be in charge, load up the Vista installation and install EasyBCD. Go to “Manage Bootloader”, then “Reinstall the Vista Bootloader”, an GRUB is overwritten. You can then configure the Vista bootloader to add Linux to the boot menu.
See I want Step by Step instructions on how to do that ^^ !
Tanmay is offline
Old 07-01-2008, 08:09 AM   #9 (permalink)
left this forum longback
praka123's Avatar
^u need to overwrite grub.with M$ rescue cd fix MBR.then try
praka123 is offline
Old 07-01-2008, 08:10 AM   #10 (permalink)
Juke Box Hero
http://neosmart.net/blog/2006/easybc...-mac-os-x-bsd/
You know EasyBCD, read its documentation.
Hitboxx is offline
How to change the boot menu text in Vista, if you are dual-booting Vista & Vista. anandk Tutorials 6 05-12-2007 02:54 PM
Need Help on Dual Booting...XP & Vista ! sudipapd Software Q&A 4 13-11-2007 07:35 PM
Dual booting SUse and Ubuntu Manshahia Open Source 12 16-02-2007 04:08 PM
Triple booting XP, Vista and Ubuntu blackpearl Software Q&A 1 06-09-2006 05:06 PM
How Vista screws dual-booting crookbond Technology News 3 22-08-2006 09:16 PM
