Old 05-01-2008, 10:52 AM   #1 (permalink)
Default drive letter..
guys i have a prob..
i have five drives c,d,e,f,g
with 2 hard disks c and d in one and e,f and g in the othr one...
now day b4 yest i connected another hard disk for few minutes, tht hard disk had two of its own partitions...so..wen i connctd tht hard disk, it took my e and f drive letters for its own and my original e nad f were shifted down to l and m...
now wen i have disconnctd the third hard drive my drive letters have not retained thre original letters in fact thy are l and m only now...bt tht makes a lot of apps not to run coz of the path chnge..
wen i go to dsk management they do not show e and f as drive letter change options evn as they r free now..!!
how do i get my origianl drive letters/?
thnks in advance
manan
magneticme200 is offline
Old 05-01-2008, 11:12 AM   #2 (permalink)
vaibhavtek
Posts: n/a
Default Re: drive letter..
strange prob. it never happen for me.
donot know what to do wait for some other members
Old 07-01-2008, 09:09 PM   #3 (permalink)
ayush_chh's Avatar
try disconnecting the drives and then reconnecting them.........
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 07-01-2008, 10:06 PM   #4 (permalink)
Google Bot
Pathik's Avatar
Use some 3rd Party Partition Manager.
Pathik is offline
Old 07-01-2008, 10:22 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Do U get any of these error:
The volume volume_label drive_letter is currently in use.
If you continue, the new drive letter will be assigned; but you can still use the old drive letter to access the volume until you restart your computer. The old drive letter will not be available for assignment until you restart.
Warning: Changing the drive letter of a volume could cause programs to no longer run.
If you continue, the drive letter will be freed; however, it will still be available for use until you restart your computer.
ravi_9793 is offline
Old 08-01-2008, 07:16 PM   #6 (permalink)
i got it solved buddies..!!
thnks..!
Old 08-01-2008, 08:28 PM   #7 (permalink)
TheSaint
NucleusKore's Avatar
You haven't mentioned what OS you are using but I'll assume its windows XP. Go to control panel and open Administrative Tools->Computer management, and in that disk management system.
Right click on the partitions to change drive letter. Start by naming the last drive Z to free up the letters and slowly change drive by drive. Its a little like Rubiks cube but you'll get it
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
How to change drive letter(f: ----> d:) CadCrazy Software Q&A 10 10-03-2007 11:58 PM
Ambiguous Drive Letter!!! IrfanK Software Q&A 3 30-07-2006 08:51 AM
Avoid drive letter change g_goyal2000 QnA (read only) 5 04-01-2006 12:39 PM
strange problem with drive letter hansraj QnA (read only) 10 12-08-2005 10:14 PM
USB stick drive letter Aijaz Akhtar Peripherals 5 12-08-2005 12:10 PM
