Old 04-01-2008, 03:19 PM   #1 (permalink)
avtarkaint's Avatar
Question problem in opening any drive
2. Whenever I double-click on any drive/folder in My Computer, a open with window opens.
how to resolve this problem frnds.
system:
microsoft windows XP proffesional version 2002
service pack 2, intel(r) pentium(r) 4 cpu 2.66GHz
248 MB of RAM
using- AVAST antivirus professional updated regurarly
avtarkaint is offline
Old 04-01-2008, 03:26 PM   #2 (permalink)
Default Re: problem in opening any drive
yeah same prob with me..!!
pls someone help..by opening any drive of my hard drive i get the "open with" window...the only way to access my drive is to write the address of the drive in the address bar..!
magneticme200 is offline
Old 04-01-2008, 03:30 PM   #3 (permalink)
Pee into the Wind...
shady_inc's Avatar
Start>Run>C: .Does it open then.??
Also you might want to have a look here in case it's a virus infection.
Life is as complicated as you say it is.
shady_inc is offline
Old 04-01-2008, 03:34 PM   #4 (permalink)
Deadman Walking
Batistabomb's Avatar
it is a autorun worm, install avast and perform bootscan so that you can manually delete these autorun-c worms
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 04-01-2008, 05:18 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
start-->> run-->> type regsvr32 /i shell32.dll -->>Ok.
Restart windows...should solve your problem..
Also check autorun files.delete all autorun files using this method:
http://www.techhunt.org/node/11
ravi_9793 is offline
Old 04-01-2008, 05:23 PM   #6 (permalink)
Deadman Walking
what this exactly do ?
Learn to live... &
Live to learn...
Old 04-01-2008, 05:43 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
some unwanted script changes the default .dll files of XP.
DLL-->>dynamic link libraries
Windows XP store information about many of their functions as dll files. Information about the DLLs are stored in the Windows Registry. When a DLL file's Registry entry is corrupted, XP may show you some unwanted behaviours.
We can fix the currpted dll files by running them again through these run commands.Even if you aren't sure what DLL information is missing or corrupted, you can run again.
Old 05-01-2008, 09:53 AM   #8 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
@ravi
thnks bro
||uLtiMaTE WinNER||
Ron is offline
Old 06-01-2008, 12:07 PM   #9 (permalink)
avtarkaint's Avatar
Question Re: problem in opening any drive
still my problem didnt sort out frnd
system:
248 MB of RAM
Old 06-01-2008, 12:19 PM   #10 (permalink)
Deadman Walking
in c: , d: , e: , f: drives you will find some autorun.inf files, first delete them
One more thing these are visible only when you checked tools->folder options->show hidden files and folders ,hide extension for known file types, hide protected operating system files
Learn to live... &
Live to learn...
Old 06-01-2008, 12:25 PM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
follow these:
Old 06-01-2008, 12:53 PM   #12 (permalink)
Do one thing..Here is the solution..
Download Pe Builder and create a windows Xp bootable cd..
Then boot the cd and there u will find a file explorer..
In that explorer u can see all ur drives..Go to C:/ there u will find autorun.inf..
Open that autorun..inside u will find a program which runs on that autorun...
Delete that program as well as the autorun file..
Do this in all ur drives....
This should work for sure...
U can get the PE Builder from here:-
http://69.90.47.6/mybootdisks.com/my...ilder3110a.exe
or from here:-
http://www.nu2.nu/pebuilder/?srv.mauj.com/blogs
Now Enjoy
Jitesh is offline
Old 06-01-2008, 12:59 PM   #13 (permalink)
thats actually a spyware/virus try running system mechanic or a good antivirus software .
Dont die of ignorance .
digitizen is offline
Old 06-01-2008, 06:29 PM   #14 (permalink)
avtarkaint's Avatar
let me try frndz
system:
248 MB of RAM
Old 08-01-2008, 07:21 AM   #15 (permalink)
avtarkaint's Avatar
jitesh how to operate pe builder
system:
248 MB of RAM
Old 19-01-2008, 09:43 PM   #16 (permalink)
Cool Re: problem in opening any drive
Its Very Easy to Use PE Builder..
Copy All the folders from The Xp Setup Cd into any folder in your drive..
Then In Pe Builder Choose that folder as source drive..
Then Put One Rewritable or writable Cd into the Drive and select the option from the PE
builder to erase and write the CD...
Then restart your computer..Boot ur CD..
Go to filemanager in PE Builder OS..
And delete the autorun Files And the Virus Exe files...
Mail me if u have any problem
niketh9)@gmail.com
Sorry mail id is niketh90@gmail.com
Jitesh is offline
Old 20-01-2008, 02:59 PM   #17 (permalink)
ayush_chh's Avatar
tell me one thing can you see your hidden files???
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 23-01-2008, 08:16 PM   #18 (permalink)
Of course..You can See each and every file on the HDD..
Try it..Good Luck
Jitesh is offline
problem in drive opening bunty007 Software Q&A 2 07-08-2007 02:30 AM
pen drive not opening sharma_atul85 QnA (read only) 4 11-05-2007 08:59 PM
Drive Not opening...plz help... bajaj151 Software Q&A 5 09-03-2007 07:53 PM
Problem with opening drive/folder achillies Software Q&A 1 28-12-2006 06:42 PM
Problem in opening the drive ajay1287 QnA (read only) 3 18-12-2006 08:57 AM
