Originally Posted by ravi_9793
Try it please..and than post the result.
don't have access to another system at moment ..... will try asap ... thanx
Originally Posted by anand1
It may also due to low Memory available. Try to shutdown all other applications before opening it. And if do not works then try to invrease the Virtual Memory of your system.
increased pf size from 370 to 740mb ..... doesn't help
Originally Posted by s18000rpm
@sandhu, do you get any error.
open Task Manager & keep a watch on the "Process" tab & CPU usage (when u open that file), if adobe gets listed & cpu usgae is ~100%, then wait for some time.
don't get any error message ........ when opening with foxit reader .... foxit reader gets listed in processes and cpu usage is 100 % ..... but document doesn't open even after waiting for an hour ...... in case of adobe ..... it gets listed in processes with cpu usage 100 % but usage drops to 3-4 % within a few minutes ...... adobe reader window opens but doesn't show the document .....and no error message is displayed
