Old 01-01-2008, 10:13 PM   #1 (permalink)
ayushman9's Avatar
Question ubunutu installation hanging
i am new to linux , and i got a ubunutu cd of version 7.10 free from some where . The cd is free of defect .I decided to test it using innotek virtualbox .i have alloted it a 2 gb hard disk space (dynamic) and 415 mb ram .Now the live cd boots (in the virtual enviorment ) properly and everything runs fine .When i try to install it ,i choose d whole hard disk option . The installation runs properly till 82% and then hang at some place called configuring/connecting mirror or some thing like that ,i tried 2 or 3 times it still hangs .
I am not able to take the risk of formatting as i have limited knowledge about linux file system .
How can i pass by these problem .
i have attached a screen shot if you want to view the stage
ayushman9 is offline
Old 01-01-2008, 10:25 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: ubunutu installation hanging
^sometimes,ubuntu finishes installation after this "82% completed" hang.
^also make sure ur partitions are OK.make sure "/" and swap of 400MB was made.
else,you have to get Ubuntu 7.10 version called "alternate CD" with text based debian installer which does the job fine.
praka123 is offline
Old 02-01-2008, 01:12 AM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Just disable the networking option in the virtualbox. And reinstall from beginning. Your installation should be fine.
debsuvra is offline
Old 02-01-2008, 02:07 AM   #4 (permalink)
in search of myself
CadCrazy's Avatar
Same problem happened here
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 02-01-2008, 04:28 PM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Well, The 7.10 version of Ubuntu (Gutsy Gibbon) tries to fetch the available updates in the time of installation (preferably when installing apt). So in the Virualbox software, there are a LAN configuring option is enabled by default. It connects to Internet through LAN when available. The Ubuntu installer gets a active LAN connection every time and tries to fetch the updates. So, to avoid this, pls disable the LAN and reinstall. It should install.
debsuvra is offline
Old 02-01-2008, 04:32 PM   #6 (permalink)
When I tried to install ubuntu 7.1 from digit dvd it stopped at 71% mark but installation was completed with another CD
ThinkFree is offline
Old 03-01-2008, 09:20 AM   #7 (permalink)
ayushman9's Avatar
Smile Re: ubunutu installation hanging
i disabled lan and network setting and installation completed . THANKSSSS
By the way can i connect to web using dataone broadband connection in ubunutu.
Old 03-01-2008, 09:41 AM   #8 (permalink)
praka123's Avatar
^yes.u need pppoe!
praka123 is offline
Old 03-01-2008, 12:40 PM   #9 (permalink)
ayushman9's Avatar
what pppoe
Old 03-01-2008, 01:10 PM   #10 (permalink)
Think Zen.
ray|raven's Avatar
Read this:
[Tutorial] Configuring an Always On DataOne on gnu/Linux
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 03-01-2008, 02:54 PM   #11 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Talking Re: ubunutu installation hanging
So at last someone thanked me, whoops !
Still not from the geniuses though !
debsuvra is offline
pc is hanging !! please help amitjoel Hardware Q&A 6 15-11-2007 05:10 PM
my pc is hanging iMav QnA (read only) 13 30-01-2007 06:32 PM
configuring net on ubunutu dhawald Open Source 6 26-10-2006 03:39 AM
ubunutu installing new appications Ramakrishnan Open Source 2 27-03-2006 01:24 PM
Hanging UPS Kalyan Hardware Q&A 2 05-11-2005 12:59 AM
- by chris
