Old 01-01-2008, 01:28 AM   #1 (permalink)
I ain't Parochial !
prashantmaxsteel's Avatar
Unhappy + (not positive) effects on My computer! Plz Help
Wherever, the computer senses a text field, it starts filling it up with + (plus sign).
It starts right from when i start typing my Xp user login paswd.
then if i try renaming a folder before i type its filled with +++++++
In opera + sign causes magnification (if i have not clicked on any text area insde its window). Hence I end up with my opera window enlarged to 1000% !
Why and from where is this auto unwanted irritating + menace coming from ?
Can anyone help me out?
I have Avast Home (updated), Spybot and Comodo Firewall.
Is it a hardware problem or my Xp Sp2 has gone nuts or some illegal intrusion/attack!
Plz Help! Its incapacitating my desktop!
S. B. F. defines me.
http://prashantmaxsteel.blogspot.com
Chemistry and Computer is my world.
Appy Fizz is my drink.
Alchemist,Angels & Demons is what i read.
prashantmaxsteel is offline
Old 01-01-2008, 01:32 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: + (not positive) effects on My computer! Plz Help
Are you sure the "+" key in your keyboard is not pressed?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 01-01-2008, 11:48 AM   #3 (permalink)
I ain't Parochial !
The key is not pressed. i mean it doesnt look to be jammed. but i ll consider it. lemme check it inside.
if u want i can put a video of it.
Old 01-01-2008, 11:55 AM   #4 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
how about an OS reinstall ?
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 01-01-2008, 11:58 AM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
before re-installing ur OS i would suggest u try another keyboard
http://beingmanan.com
iMav is offline
Old 01-01-2008, 12:10 PM   #6 (permalink)
anand1's Avatar
Yes it looks to be because of your faulty keyboard. Try to remove it's buttons and clean for stagnated particles which may have been causing the short connections.
Technology On The Fly
anand1 is offline
Old 01-01-2008, 12:25 PM   #7 (permalink)
I ain't Parochial !
thanks vishal gupta! it seems my numeric keypad's + is the culprit.
i found that this + effect begins when i have pressed the + button. it has become extremely sensitive to touch. which i think means the gap between the circuit and button has reduced very much causing such erratic functioning. hence the button might not be able to come up completely. also it seems to stop when i manually try to pull it up. (visually still the button doesnt seem to be jammed/pressed)
lemme check my friend's keyboard on my desktop.
(it seems the time has come to replace the keyboard!)
Old 01-01-2008, 12:29 PM   #8 (permalink)
I ain't Parochial !
thanks for all the replies. i will first check my keyboard on friends comp and his keyboard on mine!
still futile then i ll check it on ubuntu. (if problem still exists, it means hardware failure)
else OS reinstall.
how to convert a negative of a photo into positive using photoshop??? tango_cash Tutorials 7 21-01-2007 04:55 PM
3d Effects In Fedora Core 6 ???? paragkalra Open Source 30 06-12-2006 07:50 AM
Audio EFFECTS! upendra_gp QnA (read only) 3 28-01-2006 09:57 PM
Dolby Surround effects!!! danny_geo QnA (read only) 18 27-08-2004 08:49 PM
- by chris
