Old 30-12-2007, 06:07 PM   #1 (permalink)
cooldude666666's Avatar
Unhappy Firefox Problem
I am using Firefox Portable 2.0.0.11. Of late my firefox just either freezes up and just stays in memory but the window doesn't show. To restart it, I have to force close firefox using the taskkill command. And sometimes, when it does open up, no websites open-up. I've tried everything, even deleting the firefox folders and cleaning registry and then re-installing but nothing works. The only thing left to do is re-install windows which i'm too lazy to do.
If anyone of you can provide any way to solve this then please tell otherwise suggest any browser (save IE) which supports google toolbar. I used to use firefox for the sole reason of using google toolbar. Can anyone fix this??? Please help me!!!!!!!!!!!!!
Also if there is any log file in firefox portable that may help me in troubleshooting this problem then please tell me.
My network connection settings are also correct so please do not ask me to check that.
Keeping it Posted!!!!!!!!!
cooldude666666 is offline
Old 30-12-2007, 07:21 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Firefox Problem
Use system restore if possible.....its the easiest fix
My Stomach pains
http://tinyurl.com/32jj4m
zyberboy is offline
Old 30-12-2007, 10:41 PM   #3 (permalink)
Go to Start----Run----and type firefox.exe -profilemanger and delete all the existing profiles and create a new profile.
Note: All Firefox windows should be closed
Won't be replying to PMs for a while. Stay in touch with e-mail.
Read before asking / messaging any moderator for any query: FAQ + answers for new members
ico is online now
Old 02-01-2008, 02:02 AM   #4 (permalink)
still not working
can't do that. i always have system restore turned off.
Last edited by cooldude666666; 02-01-2008 at 02:02 AM. Reason: Automerged Doublepost
Old 02-01-2008, 02:06 AM   #5 (permalink)
I guess it is a problem with Firefox portable only......
Does the original Firefox hang?
ico is online now
Old 02-01-2008, 05:00 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
its eating ur memory [pc] .......
install only imp extensions ....... remove unwanted 1`s .......
... W H O T ...
ax3 is offline
Old 03-01-2008, 05:51 AM   #7 (permalink)
Fresh Stock Since 2005
Yes, and also disable the extensions you don't currently need and enable only when you need them.
Update to the latest version!!
http://www.khattam.info
khattam_ is offline
Old 03-01-2008, 04:43 PM   #8 (permalink)
Yes even the original firefox hangs. And not just firefox, every damn firefox compatible browser hangs and if it starts it is unable to load any website that i command it to open. One more interesting thing to look at will be that since 2-3 days, even my all other browsers, opera, safari and IE are starting to hang the only difference being that they resum from their hanged state quite quickly say in 15-30 seconds...Does this mean that this could be a windows problem? Cause I'm having another weird experience of burn failures using nero even at speeds on which i could burn easily previously.
Well for starters, I had only few extensions that were deleted with deletion of firefox and its related folders...so when i now install, there are no extensions...
Last edited by cooldude666666; 03-01-2008 at 04:43 PM. Reason: Automerged Doublepost
Old 03-01-2008, 06:00 PM   #9 (permalink)
TheSaint
NucleusKore's Avatar
Just click ctrl+alt+del and see if you have a process called svchost running in your user name. Normally it runs as system or network, but not your login name. If its there, in My Computer type the path C:\heap41a and see if it exists, if it does, you're infected
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 03-01-2008, 06:24 PM   #10 (permalink)
101101
Try Opera
Finding answers is simple, all you need to do is come up with the correct questions.
crystal_pup is offline
Old 16-01-2008, 10:25 PM   #11 (permalink)
Thanks everyone for the help. I've formatted my partition and installed win xp sp3 from ms website. The most convincing solution that was given to is I should say was that which tells about some infection. I guess I was infected but I can't be sure asi have already formatted my windows partition and everything is fine now.
Originally Posted by crystal_pup View Post
Try Opera
i guess i had mentioned this earlier...Opera was working...
Last edited by cooldude666666; 16-01-2008 at 10:25 PM. Reason: Automerged Doublepost
Old 18-01-2008, 09:54 PM   #12 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: Firefox Problem
guys open some link are not open in firefox (http://www.gg-game.com/ladder/) when i click on view the ranking of CS its nothing happen in firefox but its open internet explorer
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 18-01-2008, 10:17 PM   #13 (permalink)
Net007
Posts: n/a
I think this site only works with IE.
Old 18-01-2008, 10:19 PM   #14 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
its open with maxthon
Dell 15z + WD 2TB
iPhone 4 32 GB
PHP problem with firefox amitava82 Programming 10 29-11-2007 05:18 PM
Firefox problem AGENT_SMITH Software Q&A 1 07-01-2006 03:03 PM
Firefox problem!! jamyang312 Software Q&A 1 13-12-2005 11:11 PM
Firefox Problem! the_moon Internet & WWW 6 18-08-2005 08:41 AM
Firefox Problem shwetanshu Internet & WWW 3 28-07-2005 07:44 AM
