Old 29-12-2007, 12:07 PM   #1 (permalink)
cooldip10's Avatar
Arrow Tray Icon Problem::
Hi guys,
I recently updated my Graphics driver and a strange problem occurred. The tray icon for the Gfx is not showing up.
I am using n-Vidia GeForce FX5200 gfx card and the Drivers are latest. There's no problem with display. only the Tray Icon is missing.
How can I get it Back??
Everything is Possible
cooldip10 is offline
Old 29-12-2007, 12:40 PM   #2 (permalink)
Default Re: Tray Icon Problem::
There's a program Taskbar Repair Tool Plus(google it)...it could help you fix the problem.
a ship is safest at the harbour but thats not what its built for!
serendipiti is offline
Old 29-12-2007, 02:36 PM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Talking Re: Tray Icon Problem::
cooldip10, you have no need of that Taskbar Repair Tool Plus or something stuff to repair your case. Just follow the instruction here :
1.Open nVidia Control Panel from Control Panel
2.Click the View menu.
3.And check the 'Show Notification Tray Icon'
And then see the tray icon back again.
debsuvra is offline
Old 01-01-2008, 05:00 PM   #4 (permalink)
cooldip10's Avatar
OK. Got it..
Thanx>>
Remove security alert icon from sys tray Batistabomb Tutorials 4 16-04-2008 11:10 PM
No Windows Update Icon In the System Tray Naren Parker Software Q&A 6 17-09-2007 10:10 PM
How to hide tray icon kantiman Software Q&A 11 28-11-2006 04:16 AM
Windows update system tray icon deadly_dude Software Q&A 1 06-05-2006 02:53 PM
hide tray icon pramod_kk QnA (read only) 1 25-01-2005 11:01 AM
