Hi, I am using Linksys ADSL AM300 modem to connect to BSNL Dataone. I want to use OpenDNS for DNS Servers. I tried the method described on OpenDNS website and changed all the settings as follows:
1. Select Control Panel from the Start menu.
2. Click Network Connections from the Control Panel choices.
3. Choose your connection from the Network Connections window.
4. Click Properties button.
5. Select Internet Protocol (TCP/IP) and click Properties.
6. Click the radio button Use the following DNS server addresses and type in OpenDNS addresses in the Preferred DNS server and Alternate DNS server fields.
I typed
208.67.222.222 (Preferred DNS server)
208.67.220.220 (Alternate DNS)
Still when I log into OpenDNS Account I get error Your current IP is 117.194.65.89, but it's not using OpenDNS.
following are ipconfig details:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Hemant>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : encore-7c5c2f61
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) 82566DC-2 Gigabit Network C
onnection
Physical Address. . . . . . . . . : 00-1C-C0-09-CE-46
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 208.67.222.222
208.67.220.220
PPP adapter BSNL:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
IP Address. . . . . . . . . . . . : 117.195.64.79
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 117.195.64.79
DNS Servers . . . . . . . . . . . : 218.248.240.46
218.248.255.146
NetBIOS over Tcpip. . . . . . . . : Disabled
Please help.
