Old 27-12-2007, 06:07 PM   #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Arrow uTorrent Port problem
Pictures Explains everything
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 27-12-2007, 06:13 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: uTorrent Port problem
Have a look here:
http://portforward.com/
Life is as complicated as you say it is.
shady_inc is offline
Old 27-12-2007, 07:14 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
No, pictures don't explain everything.
Have you got UPnP enabled?
Have you opened ports up both in routers and firewalls you might be running?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-12-2007, 07:47 PM   #4 (permalink)
TheSaint
NucleusKore's Avatar
Enable uPnP in both your uTorrent and your router
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 27-12-2007, 08:26 PM   #5 (permalink)
Showstopper
Maybe ur Windows firewall or Antivirus is blocking it, access the firewall and antivirus properties and unblock it.
Also try specifying the TCP and UDP ports used by uTorrent in firewall.
Cerebral Assasin is offline
Old 28-12-2007, 01:42 AM   #6 (permalink)
As ppl have said above ::
1. Visit portforward.com
2. Find our router name and model no. (check on bottom of router)
3. Find the correct router or the nearest similar eg. If u have Motorola 7710 and they say 7700, try that .. it may be almost SIMILAR .. The correct option just may be under another suboption .. eg. Its like finding Save option under EDIT instead of File -> Save
4. If it still shows error, set port no. 54848 (around this value as it is an open port..) and SWITCH OFF PORT RANDOMIZE.
5. Then add this port to ur Antivirus (Important :: Kaspersky i had to open it .. or i simply disabled proactive defense in Kaspersky ..)
6. Do the same in firewall.
It should wrk now, otherwise ur doing something wrong. I have configure 4-5 frnds comps following this list from 1-6 and it always works. hope it helps.
ciao.
AMD Athlon 3500+ 939
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
uTorrent & Browsing Problem. Charan Software Q&A 16 09-01-2008 06:04 PM
PS2 Mouse , USB Port Problem... ~Phenom~ Hardware Q&A 19 15-12-2007 10:55 AM
Utorrent problem readermaniax Software Q&A 7 21-02-2007 11:05 PM
Problem in USB port sholay Peripherals 3 29-04-2005 02:00 AM
