Re: My friend is having a little problem with his OS [XP]
there must be some driver issues, specially sik drivers or some other which load early in the boot process.
Have you tried using the checkdisk from Recovery Console or the other repair option?
In XP setup after windows shos the first page, press Enter to setup Windows Xp, not r for repair using Recovery Console. Then Press f8 to accept EULA, after that Setup shows you a list of WinXP installations. Choose your XP installation and press the keys it says to repair it (i dont remember it). This repair is automated and will delete your windows files, recopy them and rebuilds some important settings of registry as well as reinstall your drivers. It actually halps most of the times. Try it.
Dont worry your data and softwares will be safe, only system files are restored.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
