Old 25-12-2007, 02:08 AM   #1 (permalink)
Default browser display settings or view changed
Dear friends,my browser display setting changed.if i open any web page i am unable to see the background colour ,only letters on white background is what vissible.i think my friend by mistake changed accessibility options.this view is really irritating so plz help in solving this.
thanku
Dinesh
dinesh144 is offline
Old 25-12-2007, 02:11 AM   #2 (permalink)
anand1's Avatar
Default Re: browser display settings or view changed
Make all the options in the acesibility option default and check if it is solved or not.
Technology On The Fly
anand1 is offline
Old 25-12-2007, 08:49 AM   #3 (permalink)
after changing to default settings also it dint change...thanks for the reply.
Old 25-12-2007, 09:52 AM   #4 (permalink)
anand1's Avatar
go for a system restore.
anand1 is offline
Old 25-12-2007, 10:32 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
start IE-->> tools-->>Internet option-->>Advance-->>Reset internet Explorer setting-->>reset-->>Apply-->>Ok
ravi_9793 is offline
Old 26-12-2007, 05:44 PM   #6 (permalink)
The web site MONEYCONTROL.COM is geting overlapped. If i untick the
prefernece > contents > Java script then the overlapping does not occur but I am not able to open the the other buttons. Kindly help
francis is offline
Old 27-12-2007, 12:06 AM   #7 (permalink)
Thanku very much...
visual settings of xp changed funkiguy_me Software Q&A 3 26-06-2005 05:29 PM
How to Restore Display Settings Dr. Anit Deane QnA (read only) 4 07-11-2004 08:12 AM
how to disable display settings in winxp hareshkhandal Software Q&A 5 09-10-2004 02:16 PM
- by chris
