Old 25-12-2007, 12:18 AM   #1 (permalink)
Default Want urgent help...
Dear friends. I've got the harry potter and the prisoner of azkaban game but its not running on my system. I've checked the requirements and mine are very fine. My system configuration is Pentium 4 with 512 mb ram and 32 mb video ram and also intel 82845G chipset. The problem is that when I run the game, my monitor displays "Out of range" message. My monitor is Philips 105S. I can make out from the sound that the game is running but cannot see any thing as there is the out of range message on the screen. Then I have to switch off my system. Is there any work around for this. Please help me guys.
pratik_narain is offline
Old 25-12-2007, 05:44 AM   #2 (permalink)
m@$t3r-m!nD
xzone's Avatar
Default Re: Want urgent help...
Hi Pratik, this problems usually occurs when you set the Screen Resolution of your monitor to something really high, check lowering the value to something 800x600 or 1024x768. Hope that helps
xzone is offline
How to ..... Pls its urgent csczero QnA (read only) 10 09-10-2007 04:09 AM
Urgent help plz ratedrsuperstar Mobiles and Tablets 1 01-07-2007 10:10 PM
URGENT medigit Gamerz 1 23-03-2005 05:43 PM
- by chris
