Old 23-12-2007, 02:43 PM   #1 (permalink)
aQi_g's Avatar
Red face How to connect a usb device which the win xp says as UNKNOWN DEVICE?
I want to connect the CLASSIC 732(it has a usb port for charging it) Mobile handset provided by Relance to my pc,my pc runs on Win xp SP2,When i connect the the handset using a usb cable 2 my pc,Xp me notifies me that it is a unknown device,plz help how can i connect it to the pc>is there any way?
aQi_g is offline
Old 23-12-2007, 02:53 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: How to connect a usb device which the win xp says as UNKNOWN DEVICE?
Try to install drivers.
Pathik is offline
Old 23-12-2007, 03:02 PM   #3 (permalink)
aQi_g's Avatar
Where can i get the drivers?
aQi_g is offline
Old 23-12-2007, 03:32 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Driver should be in CD which came with your hardware.
ravi_9793 is offline
Old 23-12-2007, 03:48 PM   #5 (permalink)
aQi_g's Avatar
i dont get the cd with the mobile, can anybody refer mr some internet resourses from whr i can get drivers 4 my usb device?
aQi_g is offline
Old 23-12-2007, 03:50 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
ask the shop from where U have bought.
Old 23-12-2007, 03:53 PM   #7 (permalink)
anand1's Avatar
While installing the driver, system will ask for the CD which came with the cable as u do not have the cable then go for the option of connecting to the internet for the drivers. try it out it might work.
Otherwise search the net for the driver of that particular cable of urs.
Technology On The Fly
anand1 is offline
Old 03-07-2008, 12:53 PM   #8 (permalink)
ECE0105's Avatar
You can try the Reliance Store, they may provide drivers, but AFAIK, this phone does not have any drivers.
You could also try www.rimweb.in/forums
The Forum for Reliance Handsets...
Alternatively, you can check if any other Classic Phone ( The 9 series) driver's are available and try them. Not sure though.....
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 03-07-2008, 03:59 PM   #9 (permalink)
Tech'ing life seriously!!
sude's Avatar
dear aqeel do one thing..
connect ur problematic USB device..
omce windows says its not recognised.. try connecitng the device on any other USB Slot..''
if the same error occurs do the following::
1. go to desktop.
2. alternate click on MY COMPUTER icon.. click on PROPERTIES..
3. then on HARDWARE tab..
4. finally on DEVICE MANAGER..
5. u check whether beside any device the list (which is open in front of u now) a yellow "?" is present. check under UNIVERSAL SERIAL BUS CONTROLLERS (see the bottom of the list for this entry..)
6. if yes, alternate click on that entry click on UNINSTALL.. then click on OK on the next dialog..
7. RESTART ur system and after the system boots completely.. connect the device..
It shouldnt show that error noww..
-SUDE
sude is offline
USB device not recognized ask4sumit Hardware Q&A 1 11-11-2007 07:01 PM
Want a UPS or device that can do this....pls help b_man Hardware Q&A 4 12-02-2007 01:18 AM
!!! Unknown Device !!! navino87 QnA (read only) 4 21-10-2006 05:01 PM
Remove that MTP Device, How Do I ? ShekharPalash Software Q&A 2 14-07-2006 03:55 AM
device falled gary4gar QnA (read only) 2 01-07-2005 11:17 AM
- by chris
